You opnion
Old Jan 23, 2003 | 07:14 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You opnion
As a preson who likes to plan things out before I go about doing things I wiold like your opinion on my planned mods.
Here they are
Stock 87 LG4 short block with 9.3/1 compression
Crane POWERMAX emissions legal cam model 270-114142
272*/284* adv duration .454"/.480" gross lift
Stock Vortech heads off a 5.0 ltr pickup
Kmotion springs 1.265 diameter single spring
stamped steel rockers
Edelbrock preformer Vortech intake
modified CC rochester q-jet
heddman shorties w/ y pipe and hi flow cat
Flow master cat back.
DD 2000 claims 345 horses at 6000rpms and 345 lb torque at 4500. I know that that is high (the flow charts are for 350 vortechs) but even like 325 hp would be good.
What do you all think? Do you for see any problems? Can I put a flat tapped hydrolic cam i a roller block? any feed back would be appreciated.
Old Jan 23, 2003 | 07:47 AM
ede's Avatar
ede
might help if you stated your goals and if you have e check. i'd not use the carb, any stamped rockers, or k motion products, but that's just me.
Old Jan 23, 2003 | 08:11 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
My goals are to have a moderatly fast (like high 13's) daily driver. and the car will have to pass e check. I live in ohio so the emissions isn't too strict but it will have to pass.
Gumby
Sep 28, 2014 11:20 PM
irocz253
Feb 8, 2014 05:37 PM
CamarosRUS
Apr 22, 2005 02:32 PM
84,86,88Z28
Car Audio
Mar 6, 2002 08:51 PM
