Getting My GAUGES Out
Old Jan 23, 2003 | 07:44 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a fried tach light on my 1991 z and i cant seem to get the gauges out to change it i dont wanna break anything can anyone help me out a lil bit?
Old Jan 23, 2003 | 10:17 AM
86budgetSC's Avatar
Well let getting the tach out wasn't that hard in mine.I just took of the plastic peice that goes over the clear plastic.Took the clear plastic off and a couple more screws holding the tach to the white peice.
Now getting the white piece out was the real pain!
Old Jan 23, 2003 | 10:36 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
i cant seem to get the black piece holding the clear plastic piece off. is there some trick i dont want to break it!
Old Jan 23, 2003 | 10:37 AM
86budgetSC's Avatar
No there shouldn't be a trick to it.I mean it is screwed in there.Just make sure you have all the screw out and it will come right off.
Old Jan 23, 2003 | 02:01 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
If its like my 91 rs, you have to remove the part of the dash right under the steering wheel. that will let you get to the screws that hold the plastic part that is over the gauges and steering wheel. remove that piece, and then there should be 2 screws on the top of the gauge cluster and 2 screws on the bottom of the cluster. remove them and the gauges should just slip right out(mine did) my rs didnt have any cables going to the gauges so I doubt your z would eather, which makes getting our gauges in and out eazy.
BTW all the bulbs for the cluster can be changed from the back of the gauges and if I remember right they are all 194
Old Jan 23, 2003 | 03:01 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
you have to remove the "knee pad" under the dash so you can take out those 7MM screws (2 on each side of the column). The rest of that trim piece is just "snapped" in, so it'll pop off easily enough without breaking it. you'll need to disconnect your cig lighter, fog light switch, and pull the pull **** for the headlights out. that will get the trim piece out of the way. there's a few screws (7MM) around the "lense cover" that need to come out to remove that. the ones at the top are kinda hidden. once you get that off, there's a few screws to remove the actual dash cluster, the whole thing will come out - no cables, wires, or anything. there are 4 bulbs on the back for your gauge lighting. they are integrated into a socket, they come that way. now is a good time to change the color if you want. you can get colored bulbs from somewhere, got mine from a trac auto store. the sockets can be had by themselves, too, at an auto zone, probably a couple of other places. or you can just get the replacement integrated ones. not that hard, just don't drop those hard to get to screws...
KAM
Old Jan 23, 2003 | 07:52 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks for the help guys. looks like tomorrow before work im going to change bulbs and maybe try to install my steering box brace!!!! :-D
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
