Car is jerking
Old Jan 23, 2003 | 12:19 PM
91RSmaro's Avatar
Car is jerking
Okay, I have a question for you smart guys cuz im a moron... ok if when im driving i increase my speed slowly, when i get to about 38-40 my car will start to jerk back and forth, but then when i get past that point it will ride smooth again... also if i floor it from like 25 to 50 its smooth, no jerking around 38-40... I just had the EGR valve replaced because it was busted... and before that part busted it ran smoothly at any speed... but now that I replaced that it jerks only at that speed... if someone could give me any time of clue that would be great... thanx in advanced
steve
Old Jan 23, 2003 | 01:03 PM
Vader's Avatar
About 41 MPH is the point that the TCC will lock up. You might also be feeling the EGR valve openeing at that point. Watch the tachometer when the "jerking" occurs.
Old Jan 23, 2003 | 01:21 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Mine did that and I had to basically keep the car in 5th to go anywhere. I believe mine was the o2 sensor. Don't quote me just check it out.
Old Jan 23, 2003 | 02:46 PM
canadianroc's Avatar
Ive had the same problem this summmer too. Couldnt figure it out and now its put away for the winter. It seemed to happen to me when i held a gear for a long time letting it rev up so I could hear the flowmaster But also just lettin off the gas slowing down for a light. Oh well sumthing to fix next spring.
Old Jan 23, 2003 | 04:44 PM
TAsRBAD's Avatar
I may be wrong but i am assuming that your car has a Mapp Sensor being that it is a 91. I had a friend with the same problem we replaced it and all was well They are about $25.00 at your local parts store. It should be located on the passenger side firewall.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
