Gasoline question
Old Jan 25, 2003 | 01:32 AM
Acidtalons's Avatar
Gasoline question
Is it safe to run aviation fuel in a carb-ed small block chevy? somelike like 105 or 115 octane.
Closest race fuel place is 25 miles but an executive Air port is less than a mile away.
Old Jan 25, 2003 | 04:30 AM
ede's Avatar
ede
if it's leaded and you have a cat over time it'll cause problems. if it's for the car/engine in your sig there's a very good chance you'll lose not make power running higher octane fuel.
Old Jan 25, 2003 | 10:00 AM
Vader's Avatar
Yes. Even though it's called "low lead", it still has tetraethyl lead, and will vertically fornicate your cat converter palladium coating and oxygen sensor(s) in time.
Old Jan 25, 2003 | 11:05 AM
Parrydise7's Avatar
I don't know where you are, but in California (and possibly other places as well) it would be illegal to use that gas because you don't pay any road use taxes on it (you have to pay for the privilege of driving that vehicle on the road). Did you check to see if the airport would even sell it to you?
Have you checked the price on racing gas?
Old Jan 25, 2003 | 11:22 AM
Acidtalons's Avatar
My car has no Catalytic convertor or O2 sensors, so I don't think that will be a problem.
There are no emission laws or vehicle inspections in Florida. Governor Bush ended them 2 years ago.
The reason I am asking is because my buddy and I were thinking about building a engine with 12:1 or 13:1 compression and the closest Sonoco Race fuel station is 25 miles away.
Edit- I have checked the price of race fuel, its upto 4 bucks a gallon, not cheap, but neither is aviation fuel.
Old Jan 25, 2003 | 11:40 AM
Vader's Avatar
Well, that's an entirely differnt story. Other than the lead and anti-icing additives, it's basically gasoline.
Old Jan 26, 2003 | 11:57 AM
Doctor J's Avatar
It might be a good idea to do a web search for more info. I am under the impression that AvGas has a much lower Reid vapor pressure than MoGas (something like a 100 deg lower fractionation endpoint).
You may not be able to get AvGas to vaporize without heat on the intake manifold...
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Justin92GTA
Aug 27, 2015 11:16 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
