low/no oil pressure?
Old Jan 26, 2003 | 11:35 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
got my car running but wtf, the gauge (stock cluster) is reading in the red (it moves up a little from bottom but still in the red) and when i pull off the sender wire it pegs.... my engine seems to run fine so i think im getting enough pressure.. could the sender or gauge be messed up?
Old Jan 27, 2003 | 01:06 AM
rezinn's Avatar
Yes.
Old Jan 27, 2003 | 01:35 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its a GM peice, you can count on it being off somewhat.
Old Jan 27, 2003 | 11:07 AM
Vader's Avatar
Temporarily connect a mechanical gauge to the sender test port and read the actual pressure. If it doesn't agree with the dash gauge, don't be surprised.
Old Jan 27, 2003 | 01:16 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
a couple ?s
did you build the motor?
If so did you plastigauge the main and rod bearings?
if you rebuilt it, what oil pump did you use?
and i had a 350 a while back that i quickly threw together and it did the same thing, ran good but had no oil pressure, i had the crank turned and new bearings so i thought it was alright, turns out the block needs align bored. so now i have a 406 in it that i took my time putting together and measured everything twice and out a new oil pump in and its getting 58 psi of oil pressure hot. good luck with it
Old Jan 28, 2003 | 01:49 AM
TBIfly's Avatar
now that ive let the ones with any engine know-how speak their piece.
1. did you put oil in your car when/if the engine was built?
2. are you leaking oil?
sorry to be such a simpleton
Old Jan 28, 2003 | 12:13 PM
dans82bird's Avatar
Engine: 302
yes and no.. its the stock 305, it sat for a number of months (im a lazy bastard)
Old Jan 28, 2003 | 12:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The senders go bad alot, and they don't cost much.... Personally I'd go directly to paying $18 or whatever for a new one, skip all that hookin up and fooling around, and then pay $18 and change it out anyway...
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
