Misfire?????
Old Jan 27, 2003 | 11:19 PM
IROCBandit's Avatar
Misfire?????
im guessing this is a misfire, im not sure, you tell me. at idle the tach will kind of shake and the car will run a little rough, this all started happening all of a sudden thats why im leaning towards a misfire. running between 1500-2500 it will run a little more rough with the tach bouncin pretty good, then around 3000-4000 it starts bouncing off the walls, engine chugs bad and kind of jerks the car back and forth accelerating. sort of feels like that stuck on something every few seconds. after 4500 rpm it runs smooth. should i start with plugs and work my way through wires and cap/rotor? im not sure you tell me, thanks
Old Jan 28, 2003 | 12:33 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
your timing is way off it seams if it isnt 180* out, i had a problem like this a while ago, i reset the timing to 0* then drove about 50 miles then reset it to 4* after and ever since its been fine, I AM NOT SURE BUT THAT MIGHT BE IT, just try checking the timing.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
