Pulling engine and auto tranny?
Old Jan 29, 2003 | 06:43 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Hey i was wondering if anyone has used a regular engine hoist to yank a small block with an automatic out of a 3rd gen.. if you have did you run into any trouble? im doing this pretty soon and was wondering if i can just pull em both out or if i should pull the engine then the tranny.. tryin to save a lil time here
Old Jan 29, 2003 | 10:43 AM
ckeene502's Avatar
i always take them both out at the same time. i just take out the trans. crossmember and distributor. i even kept the hood on but raised the front end way up.
Old Jan 29, 2003 | 01:37 PM
Morley's Avatar
Engine and trans will come out in 1 piece with most any hoist. just be sure to disconnect everything from the trans and support it with a jack or large block of wood until you get the hoist hooked up and leveled out a bit.
Also be aware that with the auto trans the cooling lines are held to the oil pan on the engine with some little clips.
Old Jan 29, 2003 | 06:17 PM
89RsPower!'s Avatar
k thats what i wanted to hear thanks guys! i was just lookin for some reassurance
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
