EGR code? AGAIN!!!
Old Jan 29, 2003 | 03:16 PM
Virtualdemo's Avatar
Car: 1986 IROC Z28
Engine: 400 SBC
Axle/Gears: 3.42 Limited Slip
EGR code? AGAIN!!!
Ok.... Here i go again. I had finally cleared all possible codes on my ECM when just a few days ago my car started acting up again. I can be cruisin down the freeway and i feel the engine change RPM but not speed. Everything on the road is passin me (im doing the speed limit) so i also think the speedo is off. and then after a couple of minutes the "SES" turns on. Spits out the egr code. I dont know what it could be but every stupid sensor on the car is new. Now for my question... Could this be a VSS problem. I also noticed that my cruise control works...well it works when it wants to. All the problems i have seem to point to this but i just wanted some feedback before i go jacking the car up and just wasting time and money.
305 tbi, 700R4, no catalytic converter, open air element, everything else is stock.....
Old Jan 29, 2003 | 03:39 PM
joshp14's Avatar
have you read this yet??
https://www.thirdgen.org/newdesign/t...diagnose.shtml
it might help...
Old Jan 29, 2003 | 03:45 PM
Vader's Avatar
Is the EGR solenoid operating?
Maybe you could run through the diagnostic again:
Old Jan 29, 2003 | 05:49 PM
joshp14's Avatar
vader...could you PM me and send me the TPI EGR flowchart?
Old Feb 4, 2003 | 01:39 PM
Car: 1986 IROC Z28
Engine: 400 SBC
I AM AN IDIOT
actually i am not an idiot...i should just pay more attention when Grandpa works on the car with me. My codes are coming from the 160 degree thermostat HE put in Its cool though...gives me a reason to finally buy a modified compter chip for the car Thanks for the help Vader, it actually helped me diagnose my Dad's Suburban...Made me look smart for a second at least...haha...anyways thanks again Also if anyone has any info on tbichips.com i would greatly appreciate it....
Old Feb 6, 2003 | 10:39 PM
Vader's Avatar
How about you cut-'n-paste?
Old Feb 6, 2003 | 10:53 PM
joshp14's Avatar
works for me...thanks man
Old Feb 6, 2003 | 10:58 PM
Morley's Avatar
One other thing that can set the EGR code when you are driving. If the ECM commands EGR and doesn't see the voltage signal from the feedback switch it will set the code. Those little wires on the feedback switch like to break off easily, and the wire terminal just screws into the switch, so if you loaded the wire when installing it, it could back out a ways and not make enough contact to send the signal.
Old Feb 6, 2003 | 11:04 PM
joshp14's Avatar
what switch are you talking about and where is it located??
Old Feb 7, 2003 | 12:01 AM
Morley's Avatar
On the front of the EGR valve there is a little metal thing that looks like a plug, it screws into the EGR and the single wire screws into that.
Old Feb 7, 2003 | 12:10 AM
joshp14's Avatar
so you are saying that the wire may be loose causing the SES light?
Old Feb 7, 2003 | 02:21 AM
Morley's Avatar
Could be, it did that on mine a few years ago. When you are driving steady state and the light comes on it means that the ECM has requested EGR but did not get the feedback signal saying that it opened. The switch is just an immersion thermocouple that generates a small amount of current when heated. If the EGR fails to open it won't heat up and send the signal and if the wire is broken or backed out of the switch...the ECM thinks the EGR didn't open, even if it really did.
Old Feb 7, 2003 | 02:25 AM
joshp14's Avatar
mine does that...i will be cruising down the highway at 75 and the light will just pop on, usually codes 34 and 32. cant seem to track either of them down. i received a EGR flowchart from vader and i will try that out to see if it helps. as far as the 34...i dont have a clue. but i will definately check that wire. do i have to remove the plenum..or can i access it another way?
Old Feb 7, 2003 | 03:59 AM
Morley's Avatar
For the code 34, what year is your car?
That switch is a royal pain to get to but you should be able to grab the wire terminal where it goes into the switch with some needlenose pliers and see if it is loose. Also follow the wire back to the back side of the engine and make sure it is still hooked up, along with the solinoid connector.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
92firebirdguy
Sep 1, 2016 07:53 AM
djmarch
Oct 2, 2015 10:41 PM
indygene
Sep 26, 2015 11:21 AM
Lmancha96
Sep 25, 2015 08:11 PM
