Engine knock/gas ping?
Old Jan 30, 2003 | 04:48 PM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
Hey there....I recently just read somewhere that an engine knock can be caused by a bad timing setting? Is this true? I know high mileage can cause it (and this things got ALOT of miles 160K, but still runnin strong) but is there anything else??
thanks!
Old Jan 30, 2003 | 06:17 PM
ede's Avatar
ede
too much timing, weak spark, too low octane, deposits in the chamber
Old Jan 30, 2003 | 06:18 PM
x_wolf's Avatar
Car: 91 Camaro RS
ok wel the weak spark thing woudl make sense as I'm sure the thing really needs a tune up......higher octane gas sure does help....I'll look into that stuff thanks!!!
any cheap ways to get rid of engine deposits?
Old Jan 30, 2003 | 06:58 PM
ede's Avatar
ede
mist water in the TB or carb
Old Jan 30, 2003 | 07:02 PM
x_wolf's Avatar
Car: 91 Camaro RS
thats a way of getting deposits out? or is that a reason that it may be knocking? lol im styupid so have to ask :-)
Old Jan 30, 2003 | 07:03 PM
llvll4l2c91350's Avatar
That's a cheap way to get deposits out. Hey since we're talkin about gasoline, what octane rating are you guys with stock 350s using? I've always put the premium stuff (93) since I read a long time ago that the 350 motors are high compression motors. But is 91 also good or would that be too low?
Old Jan 30, 2003 | 07:37 PM
x_wolf's Avatar
Car: 91 Camaro RS
how does that get rid of deposits? wouldn't that be bad on the engine? I would think so.....any explanation? thanks!
Old Jan 30, 2003 | 10:25 PM
It's not bad as long as it's a mist. A mechanic I used to work with suggested I do this on my car and I guess it has the same effects as if you were using one of those FI cleaners that hook up to the TB and get sucked in by engine vacuum to break down deposits.
Old Jan 31, 2003 | 12:46 AM
rezinn's Avatar
It's like steam cleaning your combustion chambers.
Stock 350s are not high compression engines and don't need 93 octane.
Old Jan 31, 2003 | 12:47 AM
x_wolf's Avatar
Car: 91 Camaro RS
so I just usea misting spray bottle and spray it into my TBI unit with the air filter off???
Old Jan 31, 2003 | 05:10 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
be sure to take off the cat first, big chuncks of carbon come out the exauast and get caught in the cat cloging it up.
Old Jan 31, 2003 | 05:57 AM
So I'm guessing 91 is ok? I've never put anything lower than that.
Old Jan 31, 2003 | 07:26 PM
x_wolf's Avatar
Car: 91 Camaro RS
so can someone run through all the steps needed to do the misting thing so as not to totally screw the engine or anything else up? thanks!
Old Feb 1, 2003 | 03:46 AM
Engine: 383
1.> disconnect headders/exauast manifold from exauast(applys only if you have a catalitic converter)
2.>remove air cleaner
3.>fill a spray botel with water
4.>rev engine to 1500 RPM's or so
5.>spray water into TB or carb keeping rpm's at 1500 or so
6.>reinstall exauast and air cleaner
7.>clean up the mess of carbon on your driveway
8.>enjoy your newfound power and the fact that you don't have to run on super everywhere
Old Feb 17, 2003 | 07:13 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
How many times should you spray the water into the carb? and could one just disconnect the exhuast before it enters the cat or do the manifolds have to be disconnected too?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
