igition switch
Old Jan 30, 2003 | 08:09 PM
mattRS's Avatar
igition switch
well, car wouldnt start today, so changed the starter. still didnt start. got told it might be the ignition switch. got three questions:
1: where is the damn thing!?!?!? looked all under the dash and couldnt find it
2: did i get the right thing? got borg warner PN CS142, has a bunch of prongs on one side, and is blue, black, and steel.
3: any other things, besides the battery-starter wire, that yal think it might be?
Old Jan 30, 2003 | 09:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds about right...
Look at the steering column where it goes through the firewall. On top of it, about 6" from the firewall, you'll find the ignition switch. They don't go bad much, but it's not impossible that it could be your problem. That would depend on what it's doing.
What are the symptoms? Does the starter do anything at all?
Old Jan 30, 2003 | 09:47 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
my car did the same thing. after 2 starters, found out it was the ignition switch...
Old Jan 31, 2003 | 12:34 AM
mattRS's Avatar
no power to it whatsoever. the starter gear isnt even clicking into position. im taking a voltmeter to it before i do the switch tomorrow. wish me luck! and thanks for the location info. i didnt look on top!!
i was too tired after the crappy day i had to do it right anyways!
Old Jan 31, 2003 | 03:35 AM
Morley's Avatar
You'll need to drop the steering column, there's a brace running across it you unbolt and let it down gently. This will make the switch change much easier, but still a bit if a pain being upside down under the dash with your head against the brake pedal.
Old Feb 2, 2003 | 02:17 AM
mattRS's Avatar
ok, got everything off except the cable that hooks to the inhibitor in the back of the switch. hwo do i get that damn thing off! the directions say slip a screwdriver in, but i dont know where to put it in!
Old Feb 2, 2003 | 08:10 AM
Morley's Avatar
I don't know, I was never able to get my cable out following the directions either, and its not like there is a lot of room to really examine the thing.
Old Feb 2, 2003 | 10:22 AM
mattRS's Avatar
so how did you end up getting yours out?
Old Feb 2, 2003 | 12:24 PM
Morley's Avatar
The inhibitor is held on the switch by a couple of little bolts, I took them out and used an ignition switch for a manual car. The manual switch is the same as the auto but costs $30+ less because it doesn't come with the inhibitor, but it does have the holes for the screws that hold it on. I installed the switch and put my inhibitor on it.
Old Feb 2, 2003 | 09:21 PM
mattRS's Avatar
got it off, now i cant get the DAMN thing back in! gawd i hate computer controlled cars!
Old Feb 2, 2003 | 11:06 PM
Morley's Avatar
That has nothing to do with the computer, every auto vehicle has one of those devices.
Old Feb 3, 2003 | 12:19 AM
curt86iroc's Avatar
Car: 1990 IROC
yea, but we still hate em
Old Feb 3, 2003 | 10:12 AM
mattRS's Avatar
thanks curt
Old May 20, 2009 | 08:12 AM
chrispotts21's Avatar
Car: camaro 1983
Engine: 2.8 v6
Transmission: auto
Re: igition switch
is this the same for a 83 camaro i have the same problem
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
