Track Inspection
Old Jan 31, 2003 | 12:14 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
Track Inspection
Just wanted to know what some of the thing are that inspect before you run your car on the track(tires,leaks,etc.)?
Old Jan 31, 2003 | 12:42 AM
rezinn's Avatar
Battery secure, coolant overflow tank in place, nothing attached that could fly off and hurt someone, nothing dripping. That's all I can think of right now.
Old Jan 31, 2003 | 06:50 AM
ede's Avatar
ede
if it's a street car there isn't much if anything they'll check, secure battery, no hub caps, over flow tank, and missing lug nuts or broken studs. if it's a race car get a rule book because there are a boat load of rules
Old Jan 31, 2003 | 08:53 AM
Vader's Avatar
Most places won't even require a helmet, cage, or driveshaft loop until you break into the 11's. I've heard that some places automatically require a helmet with converts and 'T' top cars, but not all.
Old Jan 31, 2003 | 12:23 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Wish I had a track like that around here. Byron Dragway requires a helmet when you hit 13's.
Old Jan 31, 2003 | 01:31 PM
MouseCamaro305's Avatar
over at great lakes dragaway they require a helmet at 13's and driveshaft safety loop at any speed when youre running slicks
Old Jan 31, 2003 | 07:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Neutral safety switch. General safety condition.
Some tracks require a helmet regardless of time/speed. More common is quicker than 14.0.
Old Jan 31, 2003 | 09:09 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
My track hasn't checked anything. I had a broken rear stud when I ran once and he said nothing about that, he just yelled at me for wearing short sleeves.
Old Jan 31, 2003 | 10:24 PM
1982chevycamaroz28's Avatar
when i went to englishtown they just signed my tehc card and let me in. maybe becuz it was my first time but i dunno. also at e-town they require u to wear a helmet, no matter what the hell u run.
edit: thats weird u got yelled at for wearing short sleeves. i worn my short sleeve shirts when i ran my 2 runs and wasnt told anything. all u need to wear is a shirt (no sleeveless), pants (no shorts) and shoes ( no slippers and no sandels) or boots.
Old Jan 31, 2003 | 10:27 PM
Vader's Avatar
Yeah, and too bad it isn't flat! (The track, not the helmet.) The helmet is probably for where you "launch" off the end...
Old Feb 1, 2003 | 02:35 AM
305iroc's Avatar
Car: 91 Z28
Axle/Gears: 3.42's
Well I ran my car today. Didn't have any problem passing tech. It ran 17.35 @ 78.33 mph. That was the best out of six. Never got out of second gear. All stock except for the muffler.
Old Feb 1, 2003 | 11:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
You noticed that too Vader? I thought I was just seeing things. At least they extended the sand trap at the end. That gives us a better chance at stopping before we hit the trees or the nuclear cooling towers.
Byron has the same clothing restrictions. I didn't know the first time I went. They let me race in shorts but told me it had to be pants from then on. 90 deg plus humidity and pants would be like walking around in a sauna.
Old Feb 1, 2003 | 12:05 PM
Vader's Avatar
You launch, drive down the hill, then finish up the hill. Makes me wonder who got paid how much to even get the track sanctioned. 1/8th mile times can't be right. Trap speeds have to be wrong, too.
Union Grove?
Old Feb 1, 2003 | 12:26 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Haven't been to UG yet but I heard it's better yet more expensive. I'll probably go up there at least once this season. UG is also called Great Lakes Dragway isn't it?
Gotta hit Route 66 this season too.
Old Feb 1, 2003 | 12:47 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The track I race at requiers short sleveless shirts and all the add on's when you hit 13's but time only racers get a big break as long as the car passes tech. Just make sure there isnt any cracks or large rock chips in the windshield they can get picky over the slighest thing.
Old Feb 1, 2003 | 11:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I did not get to UG since they redid the track it sucked before but, I hear it is a real track again.
Old Feb 2, 2003 | 05:29 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Throttle return springs (dual), neutral safety switch...
They are real picky at my track; you need a helmet, regardless of time; they'll check the brake pedal for feel, front end for worn steering parts, remove hubcaps and wheel centers, leaks of any kind, battery must be secured, no cracked glass...
And I just found out they jacked the rates up another $10
Pete
Old Feb 2, 2003 | 06:17 PM
yeah, i've been to the grove 3 times since they resurfaced it. weekday trial runs are $25 and the bracket is $30 l think. Its a nice place, a lot nicer than byron
Lbibb
May 5, 2016 12:00 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
jaridjohn
Oct 5, 2015 07:01 AM
bjpotter
Oct 4, 2015 07:48 PM
