305 TPI Horse Combo???
Old Feb 2, 2003 | 12:05 PM
GokuIrocZ's Avatar
How Much Would This yield for my motor....
World Torquer s/r 305 heads
New 305 block
Compcams Extreme Energy XR270HR
Hooker Comp Shorties (HetHot coated)
and a Dual 2-1/2 40 Flowmaster system
Old Feb 2, 2003 | 12:11 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
k, your cam choice is a bit much for a 305, try something like a 262 if you want a big 305 cam...and in my opinion, if your gonna run exhaust you might as well run 3"
can't say what kinda hp it'd be making because you don't give any clues as to what the intake is gonna be or what the 305's specs are...
i'd say about 60-100hp over stock if i had to take a stab at it with the limited info your giving...
Old Feb 2, 2003 | 12:55 PM
GokuIrocZ's Avatar
Well the 305 block is realitivily stock, I'm running Hooker Comp Shorties (jet hot coated) with True Dual Exhaust 2-1/2. The Heads I was going to just drop in are the World Torquer s/r 305 heads. The Intake Is TPI, With SLP Runners both intake and Runners have been ported, running with an Raptor 700r4 trans, with 3.23 posi/ auburn.
Old Feb 2, 2003 | 08:48 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
u should be expecting about 265hp.
Old Feb 2, 2003 | 09:59 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
it will take a miricle for it not to be over 300
atleast 300 and 350 tops
id say youd eb good at 330 or so
Old Feb 3, 2003 | 12:41 AM
rezinn's Avatar
I don't think it would take a miracle for it to not be over 300. The s/r stands for stock replacement, not high performance. High 200s would be my guess, but not over 300. I hope you've got some means of tuning it.
Old Feb 3, 2003 | 02:23 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
dd2000 puts you at 327/ 379 with 1.84 - 1.5 valves.
Old Feb 3, 2003 | 03:39 PM
E-Z Rollin's Avatar
With those head and the right cam,you can easily make 300 + hp . Why do some people seem to find that hard to except?
Old Feb 3, 2003 | 04:06 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Because 99 out of 100 guys with 300hp 305s are still running 14s and making excuses. I can think of very few people with 305s and the mentality of 'i'm going to keep it to be different' that actually get the cars to move.
Thats why it is so hard to accept.
Add on top of it, he is also buying a 'new block' and i don't think i'd ever worry about lining up against this guy.
Old Feb 3, 2003 | 08:46 PM
Engine: peanut LB9
itz not that hard t gt a 305tpiw/ 700r4, 3rd gen to run in the 13sec range
new plugs/wires/cap+rotor/coil $150 (back to 200hp)
edelbrock TES headers $350 (215hp)
flowmaster catback $400 (230hp)
random tech high flow cat $220 (235hp)
slp runner, port matched and port plenum $300 (250hp)
LT4 cam, 1.6roller tipped rockers $400-600 (270hp)
2400 stall converter $300-450 (better 60')
3.73 gears $300 (better 60')
hotchkis rear suspension kit $300 (better 60' due to traction)
reworked stock heads(ported and over sized valves, milled) $350-500 (300hp)
good rubber and a heavy foot $230
along with a custom burnt chip and 350 injectors--(320hp)
and now you have your self a 300hp plus motor, which could push a third gen fbody into the mid -upper 13sec range with and low 13's with a 75 shot, all for about 3 grand, and if ur smart about it you'll shop around and get better prices for better stuff-
or just drop a 350 in for 3000, and still run 14's, but k, and there no fun in that, pls he has a new 305 block to stand up to the new upgrades
Old Feb 4, 2003 | 07:34 AM
Ed Maher's Avatar
Car: 04 GTO
Originally posted by wyclefsirocz
itz not that hard t gt a 305tpiw/ 700r4, 3rd gen to run in the 13sec range... pls he has a new 305 block to stand up to the new upgrades
I'm not debating that you can't make a 305 go 13s easy. My engine is stock and my car is a tank and it ran 14.10.
But a new 305 block. Sure it'll stand the upgrades great.
Old Feb 4, 2003 | 11:52 AM
Engine: peanut LB9
ok, as long as therest of the car is in good qual;ity shape and working order. she will be quick---
but the 3rd gen fodys that have been neglected need alot of work to get there, you guys know the fbody's i'm talking about.
but neway- if you make 500hp at the crank and are only spinnin bald 225s, ur never gonna get anywhere power is only good if you can put it to use.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
