Vacuum Problem??
Old Feb 2, 2003 | 01:21 PM
z28redline's Avatar
Car: 1986 Camaro Z28
Engine: 305 lG4
Vacuum Problem??
Alright, I have a 86 LG4 and I think I have a vacuum leak somewhere because when I start my car up up the vents on the inside of my dual snorkal aircleaner won't close, the carb has a massive flat spot when cold, and I can never get my cruise control to work. Where is the best place to check the vacuum for a good reading? Would it be a good idea to just go through and replace all of the hoses? Is there any sensors I should be looking at replacing?
Thanks in Advance
z28redline
Old Feb 3, 2003 | 09:34 AM
Vader's Avatar
Re: Vacuum Problem??
Originally posted by z28redline
...when I start my car up up the vents on the inside of my dual snorkal aircleaner won't close...
By "vents", do you mean the EFE air valves? Those are controlled by a TVS mounted in the base of the air cleaner assembly. Make sure the hoses are connected correctly.
Yes, you should closely inspect or replace the vacuum hoses every 30,000 miles.
A good source of manifold vacuum is the PCV valve or the 'N' port on the carburetor base.
Your hose routing should be verified. It should be something like this:
Old Feb 3, 2003 | 06:11 PM
z28redline's Avatar
Engine: 305 lG4
Wow, thanks alot vader I really needed that diagram. Is that for all LG4's? I know right off the top of my head that my air cleaner is attached to N on the carb. instead of B that it is supposed to be. Do you think it would be a good idea to change everything to the way it shows in this diagram? Would it change anything if I have cruise control? Also i have like 5 or 6 hoses coming out my canister unlike the two coming out of the one in the diagram, do you think it is for non egr stuff??
Thanks again
z28redline
Old Feb 4, 2003 | 08:24 AM
Vader's Avatar
<h1>________</h1>
I didn't catch the fact that you may have an export model, so your '86 may not have a BARO sensor. If that's the case, your diagram should be more like this:
Old Feb 4, 2003 | 10:45 AM
z28redline's Avatar
Engine: 305 lG4
That looks alot closer to what is on the car now. I think I'm going to just go through and replace the hoses and check there routing.
z28redline
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mustangman65_79
Aug 8, 2015 12:07 PM
