valve guide clearance
Old Feb 4, 2003 | 09:30 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
How do i go about checking how much lift my heads can take, they are off the car, and are bare at the moment. what do i need to do it with, is there a height difference with stock retainers and comp retainers (which ever come with a k-kit) Thanks for any advice.
Kevin
Old Feb 4, 2003 | 10:14 AM
ede's Avatar
ede
there are several limiting factors as to how much cam you can run with a given head. port volumn, spring height, seat preasure for a given diameter spring, valve guide clearance. in relation to the springs and clearance you can fit that with soem machining as well as trashingthe pull out studs and using screw ins.
69GTOby
Apr 18, 2016 02:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
