O2 sensor?? is it really needed?
Old Feb 8, 2003 | 04:25 PM
84Z28_5.7ltr_V8's Avatar
Car: 1984 Z28
ok im pretty much a straight up moron so um.. what the hell does the o2 sensor do anywaays??? cause mine isnt connected and i think its broken. i dont even know if i have a wire to connect it to.. the computer was taken out of my car.
Old Feb 8, 2003 | 04:46 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
If your car is not computer controlled then im pretty sure you don't even need the o2 sensor but just to make sure wait for someone else to confirm this.
Old Feb 8, 2003 | 04:47 PM
Car: 1984 Z28
but what does it do??? detect what..
Old Feb 8, 2003 | 04:54 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
It measures the oxygen content in the exhaust.
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's there to detect the air/fuel mixture.
Optimum mixture is 14.7:1 at sea level. The computer uses the O2 sensor (Oxygen is what the "O" means) to sense what the ratio is based on what condition the exhaust is in.
It sends this info to the ECM by voltage. If the computer sees the voltage move from it's pre-programmed setting, it tells the injectors to give the engine either more fuel or less so the ratio stays close to 14.7:1
If you don't have the ECM anymore then the O2 sensor is just there to plug the hole.
Old Feb 8, 2003 | 04:55 PM
Car: 1984 Z28
my car isnt even fuel injected....
patrickm00's Avatar
and by doing so determines if the mixture burned clean/rich/lean. to give you an example of its effect, my 92 TA was getting 11mpg mixed driving before i replaced it, and two weeks later i was at 17ish. if your O2 sensor is more than 50,000 miles old i'd suggest replacing it.
Old Feb 8, 2003 | 05:11 PM
AJ_92RS's Avatar
Here...... I found this a while ago, I just forgot about it.
http://howstuffworks.lycoszone.com/question257.htm
Old Feb 8, 2003 | 05:12 PM
Car: 1984 Z28
wow thanks!
Old Feb 8, 2003 | 05:14 PM
AJ_92RS's Avatar
Then don't worry about it. If you don't have fuel injection, then you don't need one.
I was under the impression that you wanted to learn about it regardless of whether you needed one.
Old Feb 8, 2003 | 05:33 PM
Car: 1984 Z28
im pretty stupid, i still know the basics of an engine (what everything is/does etc. ) but i went to that site and learned more then i would have in a month. WOW should post that for all the NEWBS!!!! w00t w00t!!
Old Feb 8, 2003 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I don't have fuel injection, and I need one...
It's the feedback in a closed-loop, electronic fuel control system. All 3rd gens (delivered in the US, anyway), had an O2 sensor from the factory, whether carb, throttle body injection, or tuned port injection.
Old Feb 8, 2003 | 05:55 PM
AJ_92RS's Avatar
You're right..... I should have said "ECM" (which I thought I had earlier )
9192camaro
16
Feb 3, 2019 12:21 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
