Can't get distributor in!!!!!!!!
Old Feb 8, 2003 | 09:29 PM
87GTA Runner's Avatar
Car: 87 GTA
After finally getting all of my parts, I started to put everything back together. All was fine until I got to the distributor. I marked the rotor in reference to the body and the location of the whole distributor. But, I didn't mark the location of the rotor after it was done turning during removal. I dropped the distributor while I was lifting it up and the rotor moved so I couldn't mark the final spot. So you guessed it, it's not going back in. I spent around 5 hours fiddling with it trying every position possible, to no avail. Does anyone have any tricks they know of to help in this situation, without turning engine over to #1 cylinder and so on. I'm at my wits end and the real frustrating part is I can't take it anywhere to fix it. My car has been down since October and I can't wait to see the results of all the money spent. Can anyone please help, I would be in your debt for life.:hail:
Old Feb 8, 2003 | 09:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Stick a long screw driver down the distributor hole and move the oil pump gear alittle so the distributor will drop in.
Old Feb 8, 2003 | 10:33 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
dont know if you are supposed to do this, but i have stuck the distributor in there and turned the motor over and it fell in no problem..........
Old Feb 8, 2003 | 11:19 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
never done it but my dad told me he used too,
so it sounds like one of those old guy methods hehe
those damn pesky distributors
Old Feb 9, 2003 | 12:45 AM
88ROC1LE's Avatar
Chevy High Performance had a rookie tech session about distributor swaps, they mentioned that method as well as the "mark this, mark that" option. My dad said that the turn the motor over method is the way he used to do it!
Old Feb 9, 2003 | 08:09 AM
Car: 87 GTA
Thanks guys. Anyone else have any other hints?
Old Feb 9, 2003 | 11:56 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You don't need to move the gear much, just a tiny little touch will do it. Its so close, but still so far away!
Old Feb 9, 2003 | 01:06 PM
Car: 87 GTA
Well, I turned the oil pump a little and it went in. The marks seem off just a hair though. The rotor lines up with the body, but where I marked the body it seems off 1/4". It seems it it was 1 tooth off there would be more of a noticeable difference in the mark. I guess I'll just put it back together and pray it's right. Thanks for all the help, especially ME Leigh.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
