Is 700 CFM too big???
Old Feb 11, 2003 | 11:43 PM
CamaroX84's Avatar
My new carbed setup will consist of:
-355 ci block
-10:1 compression
-Comp hr cam (282/288 adv dur, 230/236 dur @ .050, .510/.520 lift)
-AFR 195cc heads, milled to 64cc chambers
-Edelbrock Performer RPM Air Gap intake manifold
I was looking at a Holley 700 CFM double pumper carb with mechanical secondaries. Do you guys think this is the right size carb for my setup, or is it too big and will it kill my throttle response? Any help would be greatly appreciated. Thanks in advance.
Old Feb 11, 2003 | 11:52 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
i'd say the 700 will be fine, even up to 750, but i wouldn't run a mechanical secondary unless you have a manual trans.
Old Feb 12, 2003 | 12:16 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I agree, 700 cfm should suit your engine well, especially with your cam.
Old Feb 12, 2003 | 12:39 AM
CamaroX84's Avatar
zippy, why wouldn't you run mechanical secondaries on an automatic? Thanks again.
Old Feb 12, 2003 | 10:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The engine has to be spinning in the power band when the secondaries open. With vacuum secondaries, that takes care of itself (when properly set up). With mechanical secondaries, you either need to rev the engine above that as the clutch is engaging (manual tranny), or have a torque converter that has high enough stall to be up in the power band (auto tranny). Otherwise, bog city.
Old Feb 13, 2003 | 12:37 AM
zippy's Avatar
Engine: 5.3L
he pretty much covered it. another advantage is traction as well as bog can be controlled with the sedondary opening time.
Old Feb 13, 2003 | 04:28 PM
CamaroX84's Avatar
Thanks for the replies. Can't a mechanical secondary carb be tuned to avoid bog like that? Plus I have a torque converter with a stall that goes to the beginning of my power band. Thanks again.
Old Feb 14, 2003 | 01:54 PM
CamaroX84's Avatar
btt please
okfoz
Oct 13, 2015 02:19 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
Dragonsys
Sep 25, 2015 03:51 PM
