oil pressure
Old Feb 11, 2003 | 11:51 PM
25THRSS's Avatar
HELP!!!!!! oil pressure
I have a 92 Camaro RS with a 305 TBI and the oil pressure will rise to about 45 to 50 on a cold start then slowly go down to about 15 at idle. when i'm cruising at about 50 mph it will go to about 25 to 30. My pressure seems to fluctuate depending on rpm, the more rpm the more pressure, vise versa, is this normal? What could be the problem?
Old Feb 12, 2003 | 01:00 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
that's fine. factory gauges aren't acurate, so don't worry about pressure. fluctuation is normal, cold engines, higher pressure, same w/ rpms , all ok.
Old Feb 12, 2003 | 01:04 AM
25THRSS's Avatar
so 15 psi at idle is normal, it wont go over 20 psi without a little gas normally. If i'm under 1,500 rpm that usually where it hovers
Old Feb 12, 2003 | 02:52 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
10 for every 1,000rpm's is the general rule of thumb. If you have that you are good. It is suppose to fluctuate, the more rpms you have the faster your engine is moving and the more pressure it will build up.
Old Feb 12, 2003 | 02:53 AM
25THRSS's Avatar
ok, thank you, i thought i had low oil pressure, that makes me feel much better
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
