Can i check MAF for proper function?
Old Feb 12, 2003 | 01:12 PM
holmes677's Avatar
The subject says it all. Ive got a code 33 and 36 which both lead me back to the MAF. Ive checked the relay and its good. Its an 86 LB9. Is there any way i can check to see if my MAF is working correctly or should i just go out and buy a new one?
Old Feb 13, 2003 | 09:41 AM
Vader's Avatar
Holmes,
Yes, you can test the analog output voltage of the MAF to see if it is responding at all. Connect a DVM to the 'B' and 'C' terminals at the MAF connector while it is still plugged into the MAF. Start the engine and allow it to idle normally. You should be reading about 0.075VDC or so. As the throttle opening is increased, MAF output should increase accordingly.
jklein337
Sep 19, 2018 06:23 PM
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
mustangman65_79
Aug 11, 2015 03:17 PM
