Pulling AIR, A/C, and EGR on 86 IROC
Old Feb 12, 2003 | 04:31 PM
pickardracing's Avatar
Anyone have any help on this one? I have already pulled the AC compressor, condenser and AIR pump. I want to take this crap off so i can clean up my engine compartment, lighten up and get a few ponies. I have my hood off, so im doing all the underhood stuff i can. Any help here is appreciated, im probably going to get started on it tonight. Also, any tips or clues on cleaning up wiring and other things in the eng. compartment would be MOST appreciated.
(ps sorry about the same post in the TPI Forum)
Old Feb 13, 2003 | 10:18 AM
Vader's Avatar
If you're removing the air conditioning, you might as well remove the accumulator, line sets, pressure switch, evaporator, and case, and install a heat-only duct cover. You might as well remove the AC clutch wire, pressure switch wiring (to both switches), and the A.I.R. diverter solenoid, valves, and wiring.
One note - once you remove the high pressure cutout switch, the radiator fan will run all the time when the ignition is ON. You can reprogram the EPROM or install a jumper in place of the switch to return the fan to normal operation.
BlueIroc-Z
Jun 9, 2019 03:22 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
mustangman65_79
Aug 11, 2015 03:17 PM
