Roller Rocker Question
Old Feb 12, 2003 | 07:33 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Got a question for ya all.I saw these roller tips on e bay ya you think there any good?
Heres the link:http://cgi.ebay.com/ebaymotors/ws/eB...tem=2403430325
I wrote him this letter and this is what he said:
How much horsepower are these roller tips good up to
It is RPM and valve spring pressure that's important. i use these rockers to 6500 RPM and maximun intalled spring pressure of 130 pounds and open pressure 325 pounds. Anything more and I recommend upgrading aluminum roller rockers
Thanks, Kevin @ Racers Outlet
What ill be runnin in my camaro is lunati 480/480 lift cam, Rpm intake, 600Cfm edelbrock,350 with 882 heads,3:73 gears, 3000 stall converter,Headers and so on............
Old Feb 12, 2003 | 07:40 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i was thinking about getting some like that but i dont know that they're any stronger than factory ones. they might still flex
Old Feb 12, 2003 | 08:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Rocker arms aren't rated in HP. That kind of question is sure to elicit a BS response, because it has no meaning.
I would not use them. They are basically stock rockers, still made out of stamped sheet metal. Still might as well be rubber as far as how well they transfer the cam profile to the valves.
I would also not use aluminum rckers in a street motor. Their lifespan is too limited.
Those heads will cost you more HP potential than any rockers ever will, even stock rubber ones.
Old Feb 13, 2003 | 01:40 AM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
.Thank guys,But for right now im on a budget so i have to use these heads until i can get some better heads.What would you guys recommend for a decent set of rockers at a good price.With these 882 heads im using mr gasket part #806 rocker arm stud pinning kit...
Old Feb 13, 2003 | 11:44 AM
Vader's Avatar
You can buy those same rockers from almost any speed shop for almost the same price - in either 1.5 or 1.6 ratios. Steer clear.
http://www.competitionproducts.com/page40.html
Old Feb 13, 2003 | 05:24 PM
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
So what would you guys recommend.
Old Feb 13, 2003 | 07:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Something else.
http://www.compcams.com/catalog/283.html
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
