is 40 over too much for a 1990 4 bolt block?
Old Feb 13, 2003 | 12:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
subject says it all, i was told that you cant go more then 30 over on a post 76 block due to the metal content of the blocks, i have a 4 bolt block that is already 40 over and its a bare block would this need to be sleaved or can i just use regular 40 over pistons? what sort of problems would i run into, would it be likely that i would have overheating problems or warpage? any info would be appreciated
Old Feb 13, 2003 | 01:33 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
If your worried have the block sonic checked, to measure the wall thickness. Your machinist will tell you if its good or not.
Old Feb 13, 2003 | 06:29 PM
ede's Avatar
ede
considering how easy it is to find another block i think i'd be looking for another
Frozer!!!
Jan 19, 2024 04:55 PM
evilstuie
Jan 9, 2020 08:29 PM
Djmathis123
Sep 29, 2015 01:36 AM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
