Bearing recommendation
Old Feb 13, 2003 | 04:11 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I am looking at engine bearings and there are so many, federal mogul has so many different sets, which ones you think I should buy. I have a standard crand 350 with about 10:1 comp. Should have about 400hp. And only revs to about 6000rpm. Thanks guys.
Old Feb 13, 2003 | 04:58 PM
Vader's Avatar
After laborious research and strenuous testing, the results are finally in. The best material for engine bearing shells is a compostite made primarily of finely ground bone fragments from the skull of an Al Qaeda leader or Iraqi president. Second to that, and if you're doing just a general build (and it sounds like you are), Clevite/Michigan 77s or F/M 8700-series are just fine. If you're "going goofy" with crank work and have longer fillet radii. you might need the Clevite "H" or F/M "P" series bearings
Old Feb 13, 2003 | 05:16 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
What I wouldn't pay.
Old Feb 13, 2003 | 06:21 PM
ede's Avatar
ede
i like C&A bearings from preformance applications and FM or clevite for all other, for not real reason. never had a bearing problem or failure.
Old Feb 13, 2003 | 07:55 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm about like ede.... out of all the motors I've ever built I have yet to have one fail for the quality of the bearings.
My personal preference is, new ones. They're so cheap they're not worth re-using even if they're still good.
I've used Clevite, Sealed Power/Speed Pro, Vandervell, C & A, Perfect Circle, and a few others. They've all been just fine.
Old Feb 13, 2003 | 09:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Lol..think I can "make it big" with my Osama-line of bearings?
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
