can someone please tell me how to hook up the odometer on my 83 Z28?
Old Feb 15, 2003 | 11:00 AM
Brad91Rs's Avatar
Car: 1991 RS and 1998 Trans Am
Engine: 6.0L(lq4) & 5.7L(ls1)
Transmission: 4L60e
Axle/Gears: 323
The odometer doesn't work. I want to fix it, but don't know where it is. Can anyone help me? Thanks a lot.
Old Feb 15, 2003 | 11:05 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Does your speedometer work? Because they work off the same gear.
Old Feb 15, 2003 | 11:26 AM
Marc 85Z28's Avatar
Like ME Leigh said, both the speedo and odometer run off the speedo cable. If neither work, check that the cable is intact and connected at both the cluster and the trans. If everything is OK, check the gears inside the tailhousing. If the speedo DOES work, the problem is internal to the speedo gauge - in which case you will need a new one.
Old Feb 15, 2003 | 11:59 AM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
The speedometer does work, but it's not completely accurate. So does that mean the problem is in the guage itself? Thanks again for the help guys i'm trying to fix this car up to sell it.
Old Feb 15, 2003 | 12:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup. Needs a gauge cluster.
Old Feb 15, 2003 | 12:41 PM
Marc 85Z28's Avatar
Or you could replace JUST the speedo.
How do you know the speedo is off? That might not be the problem. If the rear gears or transmission has been changed, that could make it inaccurate.
Old Feb 15, 2003 | 07:25 PM
Brad91Rs's Avatar
Transmission: 4L60e
Axle/Gears: 323
The speedometer works, it's just a little slow. The odometer doesn't work at all.
gta892000
Aug 11, 2019 11:16 AM
formula1LE
Sep 12, 2015 08:31 PM
FormulasOnly
Sep 10, 2015 09:07 PM
andy74
Sep 3, 2015 08:41 AM
