balancer question
Old Feb 16, 2003 | 01:36 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
balancer question
Is there some type of tool available to hold the balancer from turning while you tighten the crank bolt? Also does anyone know the torque specs for the bolt (90 5.7).
Old Feb 16, 2003 | 01:51 PM
ctandc's Avatar
Is the engine in the car or out of the car?
I've never had trouble tightening the crank bolt...as normally once it gets snug, it will start to turn the engine over before anything else...
More info...
Old Feb 16, 2003 | 02:04 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
It is in the car, there are no other pulleys or anything on the car though. Also I dont have the plugs in. That is what is happening, the bolt is all of the way in and now it just turns the engine over, shouldnt I torque it down now that it is in all the way? Or should I wait until I have the accesories back on and the belt and just snug it up then?
Old Feb 16, 2003 | 02:13 PM
Vader's Avatar
Bolt the crank sheaves back onto the face of the balancer, then use a strap wrench on the steel sheave. Usig a strap wrench on the outer ring of the balancer can cause the ring to slip, and result in incorrect timing marks.
A strap wrench can be purchased at many places for about ten bucks, and can be a very useful tool for rotating the engine, removing oil filters, spinning exhaust pipes, removing alternator sheaves, etc.
Old Feb 16, 2003 | 02:24 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Thanks Vader, do you know the torque specs on the bolt?
Old Feb 16, 2003 | 03:29 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm not Vader, but i think I know the specs too.... 60-65 ft-lbs (typical for 7/16" hardware)
Old Feb 16, 2003 | 07:00 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
70 lb/ft. Just did mine last night.
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
Linson
Aug 31, 2015 04:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
