What's the thing infront of my heater valve...
Old Feb 17, 2003 | 12:06 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
This black box with some hoses between my heater valve and my alternator. I've got an '87 IROC..
My '85 IROC idn't have a heater valve, or this black box, or engine cooler lines. And in not having such, was 1000 times easier to work on.
So do I need this black box?
Old Feb 17, 2003 | 05:29 AM
uk89camaro's Avatar
At a guess it's part of the AIR system (Does the black box have one hose down to the Cat, and one going into the smog tubes/headers?).
Plenty of people run without it, and the HCV. Your issue is around wether you need the AIR for emmisions testing.
Old Feb 17, 2003 | 09:05 PM
I do need A.I.R. for emssiions... it's just weird how it's routed and like I said... my '85 didn't have that black box.
Old Feb 17, 2003 | 10:59 PM
Vader's Avatar
Twilight,
Does it look like this?
Old Feb 18, 2003 | 12:36 AM
Yes it does. That black thing connecting to my smog pump! I'd like it gone, if I can by-pass it. but it has some electrical connectors that my 85 didn't have... so I don't want my ECM to go ape sh--.
I'm just trying to clean things up a bit... one by using the A/C delete, and anything else I can to make my 350 swap in the next few weeks easier.
Old Feb 18, 2003 | 08:08 AM
Vader's Avatar
Twilight,
If you need A.I.R., you need to keep the pump and that valve.
Old Feb 18, 2003 | 10:40 AM
Just out of curiousity how did my '85 run with the smog pump and air but without the box?
Old Feb 18, 2003 | 11:03 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
In 85 GM used a vacuum controlled AIR pump diverter valve instead of the electrically controlled one you have.
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Bob88GTA
Aug 18, 2015 03:31 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
