Pro Topline Torker's
Old Feb 19, 2003 | 01:11 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Im thinkin of getting these for my 350 with dished pistons, I would be gettin 67cc ones, what size valves should i get 1.94/1.50 or 2.02/1.60? would these heads be a good choice for a 350, 750 cfm carb, XR264HR 212/218 duration .487/.495 lift roller cam, 700r4 stock stall, 3.42 rear.
Also where can i get these heads cheap?
Is anyone out there running these heads, if so what is your combo, et's, gas mileage?
Kevin
Old Feb 19, 2003 | 01:38 AM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
if you want more Torque then get the ones with 1.94's, if you want more horse power go witht he 2.02's. also what matters is the collector volume that you have, having mroe of that then you also increase torgue. what ever you decide upon, good luck.
Old Feb 19, 2003 | 12:00 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Never heard of the Torkers but you can check out www.proshaver.com
Old Feb 19, 2003 | 02:38 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Check out Competition Products!!
http://www.competitionproducts.com/page6.html
tmellott89
Oct 14, 2015 02:06 PM
Pinguiclia
Oct 12, 2015 04:47 PM
djmarch
Oct 2, 2015 10:41 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
jbates346
Sep 22, 2015 05:22 AM
