A.C. Delete Who has done it??
Old Feb 19, 2003 | 07:42 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
I was going to take the AC and all the parts off my car since I dont use it and its taking up space. I am trying to clean up the engine as much as possible for engine swap and AC is not a concern. Who has done this and what did you do to make it look good?? Need to know where to get a AC Delete pulley also.
Old Feb 19, 2003 | 07:49 PM
llvll4l2c91350's Avatar
I have removed every single item related to A/C except the compressor. I have an A/C delete heater box and a pulley coming in the mail. The box I got off Ebay, the pulley from gmpartsdirect.com.
Old Feb 19, 2003 | 08:07 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I took it all off, and redid my belt so I don't need a pulley. I made plates to block off the holes left from removal.
Old Feb 19, 2003 | 08:08 PM
johnsjj2's Avatar
Car: 1991 Z-28
Heres one of the whole engine:
Old Feb 19, 2003 | 11:08 PM
Squeeks83's Avatar
Car: 1978 Chevrolet C10
Transmission: Turbo 350
now thats one ****ing clean looking engine bay. tomarrow im about to go out and drain the A/C system of the freon, dont tall no one... , then im taking it all off, and just cap it till i can go buy a A/C heater box from a friend for $40.
Old Feb 20, 2003 | 12:41 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I still have heat.....
I gave it the "Krylon touch" before install .
These boxes are getting harder and harder to find though... I got mine off the classifieds here at thirdgen... I forget who I got it from though . If you go the non-A/C heater box route you will also need a different blower motor and wheel.
Mine could look a lot cleaner, but I kept the heater control valve and have those heater hoses routed all over the place to keep them away from the engine..... not the fanciest looking setup, but it works fine and I don't have to deal with them when working on the engine.
Mine is also an 87 so I was able to just remove the A/C compressor and related brackets all together from the engine. The condensor is a simple removal with the upper radiator mount plate (the black plastic thing) removed and the lines disconnected... The lines and the accumulator are also a simple yank and toss operation as well.... I kept the wiring intact just in case and tucked it into the harnesses and taped them up.
HTH
Old Feb 20, 2003 | 12:44 AM
Damn. I guess this means I won't be able to reuse my blower assembly without some modifications...
Old Feb 20, 2003 | 12:50 AM
Matt87GTA's Avatar
Originally posted by llvll4l2c91350
Did you get a blower assembly with it or did you reuse your old stuff?
I just edited my post . I had to get a non-A/C blower motor and wheel from my local parts store and I think they ran about $40 for both (might have gotten a healthy discount though for those prices... I know folks ). I think I paid $75 shipped for the heater box.
Old Feb 20, 2003 | 12:55 AM
I paid about 45 bucks but looks like I'll be spending more.
Old Feb 20, 2003 | 04:30 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here's mine: non-AC delete box, bought it from someone here on thirdgen.org who sells them. It came with the blower motor and wheel, but I paid like $90 or so with shipping included. I eliminated the heater valve to make things a little cleaner. Also, I didnt want to cut out any of the harnesses for the AC, in case I ever want to put it back on, so I carefully tucked them away inside the polyloom, or back in the fender.
Old Feb 20, 2003 | 06:22 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
hmmm
heres what me and bluegrassz did for ours just until we can get the non ac heater boxes.....
it's great losing the ac because of the weight savings and it gets rid of the condensor so the radiator has no flow abstructions at all for better cooling.... mate that with a 160* thermostat and your set!!!!
Old Feb 20, 2003 | 04:48 PM
camaro_1983_383's Avatar
im a little confused about what all you guys did. i dont know the names of the parts that you guys are talking about very well. Please help me, what could i do to get the clean look of your bays.
Old Feb 20, 2003 | 06:05 PM
Hulk0202's Avatar
Johnsjj2 do you have the belt number? Do you have any problems with the tensioner not working? Thanks for the info..
Old Feb 20, 2003 | 06:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Hulk,
I don't have it right now, I'm at work. I will get it tonight, and post it tomorrow. THe tensioner works great.
Parrydise7's Avatar
Does anybody have the GM p/n for the a/c delete heater box? Thanks!
Old Feb 20, 2003 | 06:58 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
I was needing the part numbers also if anyone can look them up or knows them. Man yall got some clean engine bays, hope mine turns out half that good.
Old Feb 20, 2003 | 10:39 PM
ooh...ooh, i want mine to look that good to. what besides the A/c did you guys do to get it looking so good?
Old Feb 21, 2003 | 12:16 AM
vjo90RS8's Avatar
Car: 2002 Z28
I deleted mine also
Old Feb 21, 2003 | 12:18 AM
vjo90RS8's Avatar
Car: 2002 Z28
might want a pic huh
Old Feb 21, 2003 | 01:28 PM
johnsjj2's Avatar
Car: 1991 Z-28
Hulk,
The belt is a Dayco number 5060770.
Old Feb 22, 2003 | 11:55 AM
vjo90RS8, what Strut tower brace is that you have?
Old Feb 22, 2003 | 12:32 PM
vjo90RS8's Avatar
Car: 2002 Z28
Edelbrock TBI/ Carb STB , pretty easy installation, and it really tighted up the front end , about $120 i believe from summit.
Old Feb 22, 2003 | 07:29 PM
Hulk0202's Avatar
Thanks jj, I appreciate that.
Old Feb 23, 2003 | 12:14 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Here is mine...
Old Feb 23, 2003 | 12:16 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Old Feb 23, 2003 | 12:17 AM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Lastly..
Old Feb 23, 2003 | 01:14 PM
89ProchargedROC's Avatar
GM doesn't produce the Non-A/C Heater box anymore....only from private partys now
i have one for sale if interested
$100 shipped, just the box
Old Feb 23, 2003 | 05:05 PM
Hulk0202's Avatar
Damn, talk about price gouging.
Old Feb 23, 2003 | 05:24 PM
Economics baby...
demand is high, supply is low.
Notice how t-top weatherstripping price went up like 40%? GM stopped producing them.
Old Feb 23, 2003 | 05:30 PM
vjo90RS8's Avatar
Car: 2002 Z28
IROCZDAVE is selling there for about 70 plus shipping and it includes the wiring, hardware, and blower motor/fan.
Old Feb 23, 2003 | 06:02 PM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Man there were 3 in the junk yard by me when I went hunting... I took the best looking one and gave the guy $20 came with the motor, resistors, vent hose and wiring. Put a coat of flat paint on it and it looks great!!
Old Feb 24, 2003 | 06:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
WHAT??!?! Crap. I left the motor and cage-fan in the junkyard when I grabbed my a/c delete box. What's different about these pieces?? Dammit... I know I could buy a motor outright, but where the heck am I gonna get the cage fan?? Does someone still make the fan?
Old Feb 24, 2003 | 06:49 PM
Hulk0202's Avatar
Oh, so if you CAN gouge someone for money you SHOULD? Do you belong to OPEC by any chance?
Old Feb 24, 2003 | 06:52 PM
johnsjj2's Avatar
Car: 1991 Z-28
Dude, that is the funniest thing I have read all day.
Old Feb 24, 2003 | 07:10 PM
i'm not "gouging" anyone for money. I'm simply selling for what i feel the market is baring.
Tell me this...
Let's say you owned an original 1955 bel-air. Bought it brand new back in the day for 6,000. Still in good condition today but a few minor problems with the body. A little rust. Well people are paying close to $25,000 for a totally original mint example of one because they are popular. So you could probably get maybe 15,000. Are you going to try and sell it for 15,000 or 6,000?
Do you own your own home? Real Estate appreciates and you get to sell it for more than you bought.....are you gouging someone because you sat on a good piece of property until it became profitable? no. You are simply taking advantage of the market.
GOUGING someone is overcharging them for something readily available and accessable....now if you could buy the boxes straight from GM for $40 and i charged someone $100 and he paid for it, then yes i'm gouging. I'm simply trying to make a profit. Sorry you dont feel the same way.....
Old Feb 25, 2003 | 05:44 AM
JPrevost's Avatar
Car: 91 Red Sled
The motors are the same but you need the correct fan else modify. I just took the long fan and cut it down then plastic welded it back together with a cheap soldering iron.
Old Feb 25, 2003 | 03:52 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sweet! Thanks, JP!! I'll give it a shot. Maybe I'll even grab a fan from a junkyard to play with it first. Thanks for the tip on using a regular 'ol soldering iron to "weld" it back together; didn't think that would work.
Whew; thought I screwed the pooch on that one. That's the last time I ever think "oh, I have a (part name) already, I'll just leave this in the junkyard"!
[edit] Oh and regards the availability of these things; the day before I found mine, I found another one- sort of. It was in an '85 Firebird, without factory a/c- but with an aftermarket air conditioning system!! I was like "oh, cool", then "Oh, damn" when I saw they removed (and probably threw out) the old heater box. They had some homemade square box on there. I meant to go back with my $60 digital pen-cam and take some shots of it, but when I went back, the car had been crushed.
Kinda funky; they modified the original heater controls. The fan speed switch was replaced with a big combination switch (think power/volume/tone switch of an old 8-track radio) that turned the a/c on and off. Compressor was a somewhat skinny, very long Nippendenso, with a homemade bracket. It was driven off an added-on pulley to the factory crank pulley. Dammit; now that I think of it; I should've gotten the crank pulley and water pump pulley off that car for my car- the junkyard car was a 2.8 MPFI v6, same as my motor.
The worst to come out of the $100 pricetag for that box is nobody buys it, and he's stuck with it. And from the rarity of these boxes, it doesn't sound like he's bothered with being stuck with it. If I could score a second one for my future "I'm married and have a two car garage" v8 Firebird project car, I will. Besides, it's not like the box can't be fabricated.
Hey... there's an idea... who wants to make a fiberglass mold for these things? Lets reproduce them ourselves!!
Old Feb 25, 2003 | 06:46 PM
Hulk0202's Avatar
Anyone who pays $100 for a box that can easily me made for under $20-$30 is an idiot. If you can get $100 for it, more power to you my brother.
Old Feb 25, 2003 | 08:24 PM
JPrevost's Avatar
Car: 91 Red Sled
Already being done. I've got the materials to make the molds and the box's out of glass. Of course I'll be charging $65 but that comes with a modified fan just incase you don't feel like spending extra on finding one AND shipping. Oh and it'll reuse your current resistor wires for the motor speed. Oh, can't forget it'll come with hardware (shorter bolts) and a gasket. If that's not good enough for you, how's being sanded smooth and painted sound, or I could cut you a deal like DJ Sexay did with his kick panels.
Old Feb 25, 2003 | 08:57 PM
MdFormula350's Avatar
i just bought one from him, 88 bucks shipped to me..
he posted he had a few on the 19 and and on the 23 he ran out again, i am glad i got my e-mail in early!
http://members.***.net/iroczdave1/IR...rts%20Page.htm
Old Feb 25, 2003 | 10:53 PM
Matt87GTA's Avatar
Been a while, but I remember not being able to use the old motor with the new fan either... I dunno for sure though. I know I ended up with a new fan and motor when it was all said and done .
That whole supply and demand thing really baffles ya, huh.....
Old Feb 26, 2003 | 02:47 PM
  #42
Can you (or anyone who's done it) tell me exactly how you did it?? If I need anything else besides the soldering iron? I just got my A/C delete box in the mail but now I need to modify the fan. Thanks.
Old Feb 26, 2003 | 04:36 PM
  #43
JPrevost's Avatar
Car: 91 Red Sled
The fan cage has a plastic ring at the end facing the firewall. Cut this off flush. Then mark where you need clearance and cut the fins. Solder back the ring being careful to keep the welds LARGE.
Old Feb 26, 2003 | 04:49 PM
  #44
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool; make sure you let us all know when you start making them. I'd likely buy a second one (for the "future" v8 project car)!
Old Feb 26, 2003 | 05:40 PM
  #45
Thanx for the tip. I just got back from the yard and was able to find the shorter blower fan off an old cavalier. Now all I have to do is find some thick weatherstrip, stick that to the old housing and mount everything to the firewall. Oh and my A/C delete pulley came today. Already installed it. Looks good.
Old Feb 26, 2003 | 06:05 PM
  #46
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Just got my Delete pulley
OK, I just ordered my delete pulley and it looks different from the pics above. the plate the bolts go thru is only an inch thick and the pulley is only 3" in diameter. I ordered PN 10115875. It looks like it may work with some kind of spacers to make up for the plate thickness but I dont know.
Old Feb 26, 2003 | 06:11 PM
  #47
formul8!!'s Avatar
Car: 2004 GTO
Here is how I did it:
https://www.thirdgen.org/techbb2/sho...hreadid=163176
Old Feb 26, 2003 | 06:32 PM
  #48
formul8!!'s Avatar
Car: 2004 GTO
Eric,
It is the pulley at the bottom of the pic. Sorry, but I don not have any specs on it. It is a direct bolt in piece.
I purchased the pulley from gmpartsdirect.com for around $46.00.
Old Feb 26, 2003 | 06:51 PM
  #49
Good article. I'm gonna do it the same way. Right now I'm bout to paint it.
Camaro91S,
The part # for the third gen delete pulley is 10055890. You may have gotten the one for 4th gen cars. The pulley should fit perfectly without any modifications.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
