Old Feb 19, 2003 | 08:05 PM
_max_'s Avatar
ok now i know sum1 is gunna say 6speed but i aint gots the money, my berlinetta has V6 and a 5 speed in it and it wont work with the lt1 swap well just F_K NOW THE QUESTION WILL A REGULAR 5 SPEED FLYWHEEL OUT OF ANOTHER V8 3rdgenFBODY BOLT TO THE LT1
Old Feb 19, 2003 | 08:15 PM
kevinc's Avatar
Car: 1982 Z28
A flywheel from an '86 or newer one will...needs to be the 1-piece rear main seal part, pre '86 ones are 2-piece rear main seal pattern and won't bolt to the LT1 crank.
Old Feb 19, 2003 | 08:19 PM
_max_'s Avatar
thank you for that answer now how bout the tranny will any do or does it have to be an 86 or newer to
Old Feb 19, 2003 | 08:22 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Using an 86 and up flywheel, you cold bolt in any 82-92 Camaro/firebird manual transmission. The problem is that none of the manual transmissions that came in thirdgens are strong enough to hold up behind an LT1. a TH700R4 will take the power, but not a T5. I'd recommend a T56 from a 93-97 Camaro/Firebird.
Old Feb 19, 2003 | 08:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The trans does not care if the engine is a LT1. If it's a V8 trans, it will bolt up and work, as long as you use the 86-up V8 flywheel and a V8 bell housing. The 6-cyl trans will not work unless you use some other 6-cyl clutch I don't know which one, and the 6-cyl BH will absolutely not work period.
Long-term survival ios a different matter. That's a function of driver behavior as much as anything else. You can (or at least I sure can) tear up a T-5 with a 305; I can also make one live behind a 400 that eats LT1s for lunch.
Old Feb 19, 2003 | 08:40 PM
_max_'s Avatar
thanx for the input on this i can not afford a T56 rite now so i will have to go easy on the 5 speed hmm hehehe well yes a t400 trany will stand upt o any lt1 i used to have 1 in a 69sschevelle i am going to try to buy 2- 5 speeds at local wrecking yard and have 1 rebuilt with parts recomened by http://www.gearzone.net/ maybe i can do this cheaper then buying the t56 for now ?
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
