Problem with error codes...HELP!!!!!!!!!!!!!
Old Feb 21, 2003 | 04:59 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Engine: Modded 305 TPI
Ok, I've had a knock for a while and I've been trying to figure out why. I finally decided I would take the computer chip from an '86 T/A with the same motor I have in my '87 IROC-Z (LG4) and see if that fixed my problem. Well I don't seem to have the knock anymore but now I have 2 error codes:
1) Error code #41:
- EST circuit failure - no distributer pulses
- Cam Shaft Position Sensor Failure
- Cylinder Select Error
2) Error code #15:
- Coolent Sensor - low temperature fualt
I think I know why I'm getting #15 because one of the previous owners of the car rig the coolent temp fan to run all the time and I don't know how to undo this.
I don't have a clue as to what I should do for #41 and that is where I would like the most help though if you can tell me how to fix the fan problem that would be good too. But like I said I have no idea where to begin with #41. Thanks in advance.
Old Feb 22, 2003 | 09:43 PM
Vader's Avatar
If you go back to your original EPROM, do you get the same results?
Old Feb 23, 2003 | 06:55 PM
Ghigman3's Avatar
Car: '87 IROC-Z
Nope, it comes up clean.
Old Feb 23, 2003 | 08:14 PM
Vader's Avatar
My guess is that the two CALPAKs aren't compatible. What is the revision number of each EPROM (visible through the round windows in the CALPAK covers)? There should be a number like "AUM 1893" or some string of characters on a foil label.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
