Aftermarket or NOS Belt Tensioner
My belt tensioner has a crack where the breaker bar is supposed to fit in. I need a replacement but I can't find any on thirdgenresource. Does anyone know where I can get them?
Originally posted by jeffsbluez
Try your local junkyard.
I should ask, is there anyway to use the belt tensioner without a breaker bar? I won't be able to use that to get it loose since it's broken off.
At the top of the tensioner there is an opening for a 1/2 inch ratchet. Use this to pull the tensioner up. Hope this helped.
Car: 91 z28
Sorry I did not know where it was broke off at. Take a crow bar and slide it under the pully. Use the bracket as the axis.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if you dont wanna spend any money you could get a nice thick washer with a 1/2 inch square opening and tack weld it in and paint it.
Why didn't I think of that! dude! that'd work perfectly lol!!! thanks a bunch The entire tensioner is only $40 from www.GMPartsDirect.com
I replaced mine just a couple of weeks ago...
