350 or 502....
350 or 502....
Question is drop a built 350 or a 502.... i was wondering what the ups and downs are to SB and BB. Besides having to do all the supspenion, transmisson and rear end work what should i do. im looking for that mean 420ci megablower with dual 4bl carbs look haha but really what should i consider before doing anything.
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
i'd say big block.
sure, it'll cost $2k more, but you also get 200 more horses. a good n2o setup will cost you that. go all motor....and then spray.:lala:
money is definetly not an issue, i was thinking big block my dream has always been to have a megablower sticking out of the hood, i have to do my hw and plan everythign out before i make any final decisions
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Money not an issue, then don't waste it on a GM 502. Step right up to any aftermarket 540 for about the same price. There are many good packages out there. Just pick up a copy of National Dragster and look through the ads.
Car: Formula
Engine: 5.0L
Transmission: 700R-4
Money's not an issue
If money is not an issue, there is an engine combo in this months Popular Hotroddin that promises 1100Hp off a naturally asperated 632Ci. They also advertise that it'll run on 93 octane. I think it costs something like 8 or 9000.
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Yeah, if money is not an issue. I too recommend something like a 632 big block or a 454 smallblock (World Products Motown block based). I like the looks of World Products stuff and if I had the money, I'd be all over one of them. The smallblock would probably be easier and still put out some WICKED power. You could even get it built for an ATI Procharger or spray it w/ a 250 shot.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
****, go with the new aluminum ZL-1 427, and a 8-71 blower on top. This way it will be light as a small block and you will have that blower you want.
Car: 87 IROC L98
I don't recommend anything bigger than the 540 unless you intend to do a lot of chassis modifications. Sure it's nice to get a 632 but that's a tall deck engine and doesn't fit quite the same way.
The 540 is the biggest short deck block and will have the same dimensions as a 396, 427, 454.
Not related to F-bodies but here's a local street legal, low 10 second, blown 65 Fairlane. There's also a link on this site to a Chevelle with a 632
www.blownfairlane.homestead.com
im not looking for a full out crazy car that im going to have to kill myself with supspension, i just want it mainly for show, a street car in the 11's or 10's that safely can do it... whats a good site for blowers? the only site i could find was holley but i don't really care for thier blowers as much as i have seen on some other cars, what are the main things i have to consider before doing this?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I know you want the big blower, but if you want to be unique (not a 300HP 305
) then get the ZL1 through www.paceparts.com
http://www.paceparts.com/product.asp?3=56150
It's only a ~$21,500 510HP 454cid
But their advertising only 200 of them are gonna be made.
) then get the ZL1 through www.paceparts.comhttp://www.paceparts.com/product.asp?3=56150
couldnt tell ya what a rat motor is but i'll tell you this..... If you want mainly a show car that'll run 11s or 12s.... that is smallblock territory. Your gonna want nething from a 350-400. Id say 400.... heh just cuz it's bigger. you should run a 8-71 on one of those.... well i dunno you could probly run 10s with a blown smallblock....u pick.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Originally posted by zr1 32 16 405
thats a great site, one question... i have heard this term alot of times.. what is a rat motor, is it some sort of big block
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
exactly. SBC is called a mouse motor because of it's physical size, and a rat is bigger than a mouse. BBC is bigger than SBC, so it's a rat
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
endless money? i want your job! check out a 14-17 littlefield blower, that would be cool sticking through your hood!
FormulasOnly
Sep 10, 2015 09:07 PM
