tbi losing oil pressure
Old Feb 22, 2003 | 11:14 PM
rodrigo diaz's Avatar
Car: 92 rs
Engine: 5.0
Transmission: 5 speeds
help!!! my car is losing oil pressure it used to have 30 psi at idle whn warm and max (60) as soon as you touch the throttle now its stay at about 20 and maxes out at about 45, its a 92 rs with the tbi v8 and a five speed and has 110000k
Old Feb 23, 2003 | 12:19 AM
25THRSS's Avatar
i asked the same thing a while back and found out its normal. 10 psi for every 1,000 rpm is just fine.
Old Feb 23, 2003 | 12:23 AM
Car: 92 rs
Engine: 5.0
yeah but this just hapen overnight so today i changed the oil and filter and the oil pressure sender and still reads the same low
Old Feb 23, 2003 | 12:26 AM
25THRSS's Avatar
it could be the oil pump, but i doubt it, the stock guages in our cars arent exactly the most acurate things in the world either, so you might want to consider that. Did you change the weight of the oil before it went down?
Old Feb 23, 2003 | 12:32 AM
Car: 92 rs
Engine: 5.0
no i always used the same oil , castrol 10w40 and fram filter , the engine has no knocks or noises on startup so its maybe the gauge i hope , i just bought headers, dual cat setup and 3 inch exsaust system and i have been worry all day about this
Old Feb 23, 2003 | 12:37 AM
25THRSS's Avatar
i really wouldnt worry about it. 20 psi at idle is more than fine. Mine only idles at 15 psi at idle when warmed up and goes up to about 45 to 50 at full throttle. If you really wanna find out hook an aftermarket guage up to it, but most likely everything is fine. By the way, post your gains when you install the whole exhaust
Old Feb 23, 2003 | 07:04 AM
ede's Avatar
ede
don't worry about it, you don't have a problem. if you want to better know what you have screw a mechanical gauge into the block. the factory set up isn't very accurate or reliable. 10psi per 1000 rpm is good oil preasure.
Old Feb 23, 2003 | 11:53 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
did i hear a Fram filter was used? :nono:
Old Feb 23, 2003 | 02:14 PM
Car: 92 rs
Engine: 5.0
yeah idid but i mostly use the delco one
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
