Will a flat base air cleaner work????
Old Feb 23, 2003 | 07:15 PM
CamaroX84's Avatar
My intake setup will consist of:
-Edelbrock Performer RPM Air Gap intake manifold
-Holley 700 double pumper carb (4150 series)
-Open element air cleaner
I have the ASCD ram air hood on my camaro, so it basically has the same clearance as a 1.5" or 2" cowl induction hood. Will a flat based air cleaner work, or do I need to go with a recessed base? I want it so that the filter is pretty close to inline with the ram air opening. Thanks in advance.
Old Feb 23, 2003 | 08:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it would probably work with a small filter but if you go with a drop base you will have the option of using a much larger element filter.. im not sure about your carb.. i have the same intake but i have a 650 dp and a drop base will not clear the rear fuel bowl.. i have a drop base with a one inch spacer under it to provide some clearance and i have a 3 inch element and a 4 inch cowl hood and that leaves me with about a cm of hood clearance
Old Feb 23, 2003 | 10:52 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The flat base fit my setup with a 14x3 filter until I needed to run a carb spacer because the outer threads on the manifold got wiped beyond repair.
Old Feb 24, 2003 | 01:54 PM
CamaroX84's Avatar
SSC, which intake do you have on your setup?? Thanks for the replies.
Old Feb 25, 2003 | 12:58 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
heli-coil's work wonders
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
