well i got my new engine started....
Old Feb 24, 2003 | 08:31 PM
sublime7880's Avatar
for the past month I have been rebuilding my 305 and bought a stage II trans. I got her started today but.......
She idles good but when i give her gas she stumbles but dosent die. I have timing set at 8 degress (my only mod done on the engine was a lt1 cam and she needed to be bored .30 over
I also tried adjusting the tv cable on the trans but when i follow the book's instructions, the cable doesn't ratchet back when the throttle is opened. is the linkage possibly broken or am i doing something wrong? I haven't drove it yet because I want to get this stuff set up right before i do. Anybody?:lala:
Old Feb 24, 2003 | 09:16 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
That sounds like a timing or fuel issue to me. I would check the timing again and fuel pressure. Also check for any codes or, if you can, hook up a scanner and see what the computer is doing.
Old Feb 24, 2003 | 09:49 PM
it hasn't trown any codes or anything does the computer have to re learn the engine or something?
Old Feb 24, 2003 | 10:31 PM
NTChrist's Avatar
You know to disconnect the ESC when you're checking timing on TBI engines, right?
If you're running 8* with the ESC disconnected, that may be too much advance.
BTW, you'll probably get more knowledgeable answers of the TBI board. There are lots of guys that know their stuff there.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
