Thumping Noise
Old Mar 2, 2003 | 03:47 PM
jdrafke's Avatar
Thumping Noise
Well guys i was on the way home from the g/f house and drove about 20 miles so the tranny was warmed up. And when i put it in reverse and hold the brake i hear a thumping noise. Once i let off the brake its fine and goes in reverse ok its onyl when i hit the brake. Also i turned the well once when turing sharply to the right and i heard the noise again its just a low thumping. Whats up? Help polease
Old Mar 3, 2003 | 01:57 AM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Theres lots of things that could cause a noise like that but the first thing I would check is the transmission mount. If its cracked or broken it will cause a thumping noise.
Old Mar 3, 2003 | 10:34 AM
Vader's Avatar
Good advice. And while you're under there, check out the torque arm mountings too.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
