how can i gain clearance?
Old Mar 2, 2003 | 05:16 PM
KsKid's Avatar
i started out with a stock v8 engine in an 83 camaro with an edelbrock carb, edelbrock open element air cleaner, 1 inch spacer between the carb and aircleaner and a 1 inch adapter between the intake and cab. today i put in an edelbrock performer series intake. now i dont need the 1 inch adapter but everything else is still the same. my problem is that i dont have any clearance between the bolt on top of the aircleaner and the hood. i allready have a fugly dent in the center of my hood because of this and i'm not shutting my hood again untill i get it fixed. what can i do to gain more clearance? other than buying a new type of hood? thanks alot for any info
Michael
Old Mar 2, 2003 | 05:22 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The solution is here.
https://www.thirdgen.org/techbb2/sho...31#post1175731
Old Mar 2, 2003 | 06:15 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
Transmission: 700R4's
In my case, that was only part of the solution. I also had to cut down the air cleaner stud.
-Jeff
Old Mar 2, 2003 | 07:29 PM
KsKid's Avatar
ok i'm an idiot, whats the air cleaner stud?
Old Mar 2, 2003 | 07:34 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
It's the threaded rod you put the breather's wingnut on.
-Jeff
Old Mar 2, 2003 | 07:35 PM
KsKid's Avatar
i've allready done that, its down far enough that i only get a turn and a half from the wingnut, and the wings on the wingnut have been cut also... its pretty much a really skinny bolt
Old Mar 2, 2003 | 07:42 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
In that case, I'd recommend getting the dropped base that f-bird'88 mentioned.
I'm running a dropped base and a 14" x 2" filter. I've got maybe a 1/2" of clearance
between the wingnut and the hood.
-Jeff
Old Mar 2, 2003 | 07:45 PM
KsKid's Avatar
where can i pick one of those up at? i checked all my magazines and didnt see it. and how much would it cost?
Old Mar 2, 2003 | 08:05 PM
jwattsjr's Avatar
Car: 84 & 86 T/A
Engine: LT-1 & 5.7L
I don't know. You might try Mid America since tthey specialize in 'vettes.
Mine was in the car(but not intalled) when I bought it.
IIRC, Summit also carries 'em, but I don't remember the price range.
-Jeff
antman89iroc
36
Jan 31, 2016 08:42 AM
91 SrS
Oct 7, 2015 04:32 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
