Viton Valve Stem Seals
Old Mar 3, 2003 | 02:52 PM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
I have a set of Vorted heads that have been machined for larger springs and more lift. I am now trying to find a set of Viton valve stem seals for these heads. My guides are .531 OD and my valves are 11/32. I want a positive type of seal, but I don't want teflon. Any ideas where I can pick up a set of Vitons or similar seals? I have checked Summit and Jegs with no luck.
Thanks,
Brandon
Old Mar 3, 2003 | 03:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What's wrong with Teflon ones? Last too long?
Old Mar 3, 2003 | 04:17 PM
b91z28's Avatar
Car: '91 Camaro Z28
Engine: 5.7L
Teflon tends to allow more oil past the valve stem after it starts to wear. The rubber Viton seals don't have this problem. The teflon doesn’t actually wear so much as it basically gets wallered (is that a word?) out. The up side to teflon is less resistance. I'm looking more to the longevity side of things.
Old Mar 3, 2003 | 06:44 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
When I needed new seals during the rebuild, I went to Auto Zone and asked for seals for a 98 Chevy truck. They gave me Fel-Pro seals exactly like you want. But, they only have 8 seals, and 8 O-rings. So you will need 2 packages. Cost for the one box was like $8 if I remember.
Old Mar 3, 2003 | 07:06 PM
kevinc's Avatar
Car: 1982 Z28
For a racing engine I like Teflon stem seals, but on a street-legal engine the oil burning at startup can cause trouble w/ the cat over time. I've never had an engine I built, nor seen one anyone else built, that didn't do it.
There are those new dual-material seals that look interesting...Viton or rubber at the outer edges, then Teflon in the center. I'd be interested in trying a set of these...all the cold-start sealing of Viton, and the longevity of Teflon.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
