foglights???? distributer???
Old Mar 4, 2003 | 07:51 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
i keep blowing up my passinger side fog light (and i do mean blowing it up as in exploading) i was wondering if this keeps happening because the power wire for that side is running across the firewall near the distributer????
after i replace it it will work for awhile then after a few times of use it exploades the bulb???? i dont get it if it was a spike of some sort wouldent it blow the fuse first??? im just wondering thanks for you help
Old Mar 5, 2003 | 02:57 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
are you srue you're not touching the actual glass part of the bulb when you're replacing it? i know the oils from our hand can cause the bulb to explode when heated. use latex gloves next time to prevent that to reduce one variable
Old Mar 5, 2003 | 05:51 AM
Car: '88 GTA
Engine: L-98
nope im very careful of that...btw there aftermarket fog lights not factory im gonna try to redo the ground this weekend and ill see what happens
Old Mar 5, 2003 | 11:14 AM
nikh23's Avatar
hmmm, i don't think the wire running near the distributor would necessarily be the problem. Perhaps the harness that plugs into the bulb is bad?
Old Mar 5, 2003 | 04:47 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
check the wiring again, how do u have the switch hooked up is it the oem foglight switch or is it aftermarket
Old Mar 5, 2003 | 07:18 PM
Car: '88 GTA
Engine: L-98
it an aftermarket rocker switch....the funny thing is that it didnt do this when i first installed them....ive tried diff wattage bulbs even it dosent matter it still makes them explode.....i guess you get what you pay for they were like35-40 bucks at pep boys i think they were called "blazer" fog lights???? they look like fourth gen foglights kinda i dunno im gonna look at the whole system this weekend thanks for your help guys i do appreciate it:hail:
Old Mar 5, 2003 | 07:52 PM
nikh23's Avatar
hmm i think a couple of the members on the have those blazer foglights because they look similar to the OEM foglights but havent' heard of this problem from them. I agree with the other statement about checking all the wiring again if you've already exhausted other possibilities
Old Mar 5, 2003 | 10:00 PM
Engine: peanut LB9
how do you have the switch wired and is there 2 or 3 prongs on the back of it.
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
pimprs
Aug 24, 2015 11:20 PM
