antifreeze disappearing
Old Mar 5, 2003 | 03:11 PM
cherrybombZ28's Avatar
Car: 83 Z28 camaro **SOLD**
Axle/Gears: stock
where would the antifreeze go if it isn't leaking out and the car goes through about a gallon every two days??
1983 Z-28 Camaro 305CFI Factory original
Old Mar 5, 2003 | 03:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's leaking out...
Probably the water pump shaft seal
Old Mar 5, 2003 | 03:26 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Head gasket leak & it's burning it off.
Old Mar 5, 2003 | 08:29 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Or an intake manifold leak. Is the car running OK? Check your oil.
Old Mar 5, 2003 | 09:43 PM
Open_Slot's Avatar
Could be engine crack, mine 305 would do that just not as fast. When the camgear broke and I went and had the engine washed and plugged I got it back early with "we found a crack". Yep, a 2.5 inch crack in the valley on the passenger side.
gta892000
Aug 11, 2019 11:16 AM
Toolsin
Feb 2, 2016 06:55 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
bryan623
Sep 19, 2015 10:13 AM
zeitghaist
Aug 18, 2015 07:33 AM
