Colder Plugs?
Old Mar 7, 2003 | 11:29 AM
B4C Hawaii's Avatar
Colder Plugs?
How do you get a colder plug? What do you ask for at a auto parts store? How can you tell the heat range is colder? Thanks in advance.
Old Mar 7, 2003 | 01:46 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You'll have to go there and hope for the best.
It's hard to tell you the difference because every company uses different part #s for their plugs. Some use the 2nd digit, some use the 3rd, etc.
Try a local parts store, or a GM dealer. The 'box stores' like AutoZone and Super Trax aren't exactly flourishing with knowledgeable staff.
BTW, why do you think you need colder plugs?
R U GETN NAUS?
Old Mar 7, 2003 | 02:05 PM
B4C Hawaii's Avatar
R U GETN NAUS?
Yes, I have a 100 shot, and need info on colder plugs.
Old Mar 7, 2003 | 02:18 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
It's as easy as knowing how your manufacturer of choice specs heat ranges. For example, with AC plugs for the standard iron heads on our car you'll have something like an R43TS. '43' is the heat range. Higher numbers are hotter, lower numbers are cooler.
With only a 100shot plug heat rage shouldn't be too big of a deal i would think. As long as you aren't running some kind of gimmick plug anyway. If you do a lot of short trip driving, going colder on the plugs is just gonna leave them fouled.
Old Mar 7, 2003 | 02:24 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Autolite: lower number is colder
NGK: higher number is colder
GM: lower number is colder
Champion: all over the place
Old Mar 7, 2003 | 02:34 PM
B4C Hawaii's Avatar
Thanks Ed.
Old Mar 7, 2003 | 03:35 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Colder Plugs?
http://www.cardomain.com/member_page...=217306&page=2
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
