Will engine run with no EGR and stock computer?
Old Mar 7, 2003 | 06:52 PM
Nasty_Bird_'90's Avatar
I'm expreiencing a no-start on my new L98 and need to know if the stock computer will run the engine with no EGR. Just wondering so I can take that off the list of things that could be wrong. I know if you push the vaccuum diaphragm on the EGR valve when the motor is running that it will shut itself off and I'm wondering if thats what is happening, just without the EGR valve in place. Thx.
Old Mar 7, 2003 | 07:30 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yes. I no longer have an EGR valve because my Performer intake has no provision for one. There is a little electronic solenoid for it which controls how much vacuum the EGR valve gets. I simply took mine off and left it unplugged, and it does not get a check engine light.
Old Mar 7, 2003 | 09:06 PM
Damon's Avatar
Yes. The ECM has no way of DIRECTLY knowing if the EGR valve is functional. At cruising speeds it can sometimes INFER that it has been deactivated by looking at other sensors and throw a Check Engine light (my 91 GMC Jimmy with TBI injection system takes about 3 minutes of steady highway cruising to pop a Check Engine light) but it will in no way cause a no-start condition.
Old Mar 7, 2003 | 10:05 PM
Thanx guys. Now I can rule that idea out of the equation.
Old Mar 8, 2003 | 04:28 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I should run if the valve isn't leaking. On my Crossfire eng, I made my own gasket under the EGR. My custom gasket had no holes, so it sealed off the ports, but everything looked stock.
On my 87 L-98 intake (my parts car), there's a small temp sensor installed right under the EGR.
I thought that if the sensor didn't see a rise in temp after valve was commanded open, it would throw a code. Not 100% sure abt that though.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
