Problem: If I pump the brake pedal at a full stop (neutral) rpm's shoot up???WTF??
Old Mar 11, 2003 | 02:22 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I've had this problem for a while now. If I pump the brake pedal like 5-7 times or so pretty fast when I'm at a stop or in nuetral ( car is a 5 speed) the rpms shoot from the 900 rpm idle up to like 1600 rpm. Someone said it could be a damaged brake booster. i am going to replace the little in-line black thing on the vacuum line first...( I think it's called a modulator or something).
What do you guys think this is?
Old Mar 11, 2003 | 02:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a rich idle condition. By pumping the brakes, you're adding air to the intake charge (via the vacuum booster). If idle goes up when you do that, then it's too rich when you aren't pumping the brakes.
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your brake booster "uses vacuum". That means every time it does something, it lets a little bit of air into the intake, via its tube.
It's normal. Some cars do it more than others, but all do it to some extent. In some cars, the RPMs change detectably just from one push sometimes.
1992 Trans Am
May 10, 2023 07:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
