Car won't Start
Old Mar 11, 2003 | 06:55 PM
5.0Camaro's Avatar
Car: 1991 camaro Z28
Car won't Start
Alright well i'm new to the site so bare with me. Well i got in my car today and i turned the key and nothing. like absoulty nothing. Woudn't crank or anything, it was like i was turning the key for fun. But the odd part is i have power to everything, windows work, cd player, everything, i just can't start the car. I tried push starting the car and that woudn't work either. It would like start but barly run and then die after about 2 sec. Then all of a sudden about 10 min a later the car just started like normal and its fine now. The thing is it used to do this a lot last year and i thought i had a dead spot on the starter so i replaced the starter around july of last year and it has been fine until today. So i was wondering if any of you guys have any sort of an idea why it woudl do this. Any comments would be very helpful
Old Mar 11, 2003 | 07:08 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
it could be your ignition switch......if i remember correctly when mine went i still had power to all the acessories like you described.
Old Mar 11, 2003 | 07:11 PM
5.0Camaro's Avatar
Thx a lot i'll try to look at that tommarow morning in my auto class.
Old Mar 11, 2003 | 09:31 PM
camaro_1983_383's Avatar
i would check your neutral safety switch. im guessing you have a manual. thats a little harder but on my car(when it was a manual) i would sometimes have to slam the clutch to the floor to get it to start. just a thought.
Old Mar 12, 2003 | 11:20 AM
Vader's Avatar
Another thing to watch when you attempt to start is the temperature gauge and dash warning lamps. If the temperature gauge does not go to full-scale, the crank circuit is not be closed by the switch. If you have a tilt steering column, try starting with the column tilted to the lowest position. This tends to take up slack in the ignition switch linkage.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
