Really Old Gas
Old Mar 11, 2003 | 07:54 PM
1989CamaroRs's Avatar
Really Old Gas
Im close to getting my camaro to run. The gallon or 2 of gas in it is about 2 years old. Obviously I need to drain it. Im just wondering if theres any treatment or cleaning that I need to do to the tank?
Old Mar 11, 2003 | 08:21 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
stabil should be added before you stored it. Maybe add some heet.
Old Mar 12, 2003 | 11:31 AM
Vader's Avatar
Instead of draining the existing fuel, top off the tank with fresh LOW octane fuel. Lower octane fuel is more volatile, and should help dilute the dead fuel in the tank. It would be good if you could fill it with an ethanol-blend, in case there is any latent moisture in the tank along with the old fuel.
Of course, if the tank is rusted internally, you'll need to drin and flush the tank before you do anything.
In any event, you'll need to install a new fuel filter right away to trap anything that has fallen loose or precipitated from the fuel. You may need to change the filter again in a couple of months just to make sure you trap all the debris. Hopefully, the pump will tolerate anything it sucks up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
