Vacuum and coolant diagrams
Old Mar 11, 2003 | 11:21 PM
AstroturfHead's Avatar
Anybody know where I can get some quality vacuum and coolant diagrams? I need to replace all the lines (ANd i found one of those pinhole plastic **** brittle vacuum lines broken)
Old Mar 11, 2003 | 11:45 PM
88TAJeff's Avatar
Car: 88 T/A
I have to replace mine too. Anyone know why they used that hard plastic stuff ?
Old Mar 11, 2003 | 11:51 PM
cus there dumb. Can I replace all of the brittle stuff with rubber piping?
Old Mar 11, 2003 | 11:55 PM
88TAJeff's Avatar
Car: 88 T/A
I can't see why not. Any objections, anyone?
Old Mar 12, 2003 | 06:04 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
these might help 85-89
Attached Thumbnails Vacuum and coolant diagrams-1985-89_f_body_tpi_vacuum_lines.jpg
Old Mar 12, 2003 | 06:05 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
90-92 oops pic didn't attach
Old Mar 12, 2003 | 06:07 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
90-92
Attached Thumbnails Vacuum and coolant diagrams-1990-92_tpi_vacuum_lines.jpg
Old Mar 12, 2003 | 08:10 AM
Oh man that is GOLD thanks!
Old Mar 13, 2003 | 01:01 AM
bigals87z28's Avatar
Car: Check The Sig
does anyone know if you can remove the CCV tube, and replace it with a breather?
Old Mar 13, 2003 | 06:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Why would you want to do that? Do you just like having oil all over the top of your valve covers or something?
In any case, if you have a MAF car, no. All the air that passes through the crankcase has to go through the MAF first, and get incuded in the MAF's metering. That's why the CCV tube is behind the MAF, in front of the throttle body.
Old Mar 13, 2003 | 08:01 AM
anybody know if its ok to replace those brittle plastic vacuum linesd with small rubber lines and a number of tees? Just wondering if that will mess anything up or what not. THanks
Old Mar 13, 2003 | 08:19 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes you could do that.
Or, you could go to Auto Zone or Advance or wherever, and out on their aisles, they have the plastic line and fittings and all that. Makes a much more sanitary job than the much fatter rubber line.
sheachopper
Jul 31, 2019 11:27 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
