roller rocker and centerbolts??????
Old Mar 12, 2003 | 12:47 PM
black84-6spdz28's Avatar
will 1.6 roller rockers fit under stock center bolt valve covers?.....
Old Mar 12, 2003 | 02:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'm going to assume you're talking about stock heads too.
No.
The adjustment nuts are too tall. Some aftermarket heads have the VC rails built up high enough that they will clear the nuts.
And, some roller rockers (the better ones usually) are too wide for the thing the bolt goes through to fit between them. Although, I've heard it's possible sometimes to adjust the width of that to where it will fit.
And you will have the same problem with the oil baffle for the PCV.
Old Mar 12, 2003 | 07:38 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
I have 1.6 Crane Gold RRs with stock centerbolt valve covers on AFR 190 heads and they fit. Not sure if there is a clearance difference because of my heads though as RB83L69 mentioned.
Old Mar 12, 2003 | 08:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those Cranes are the same as the GMs... I don't have any way of knowing this of course, but I suspect that the main reason GM sourced Crane for those instead of something sensible (steel) like the Comps, is because they fit, but the good ones don't.
Old Mar 12, 2003 | 11:34 PM
my heads are pro topline vortec heads....hopefully they fit.....
Old Mar 13, 2003 | 04:04 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I had to cut some metal out of my valve covers to make them work.
Old Mar 16, 2003 | 12:13 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Somewhere on here I read that Harland Sharp rr's fit under the stock covers.
Old Mar 16, 2003 | 02:01 PM
Birdman7389's Avatar
allright, iv'e got stock heads and covers, and comp pro magnum 1.6's. I only had to trim a little of the interior sheetmetal bracing on the valve cover, justt look under as you put the cover on, and you will see where to trim it. no biggie.
Old Mar 16, 2003 | 03:42 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Birdman7389....Man am I glad to hear that! I just sold my comp magnums, and bought a set of the promagnums. Still waiting on the ups guy I used proform (crap) and comp magnums with my centerbolt covers and they fit fine. I like the quality of the factory covers over the aftermarket stuff.
This was with Trickflow heads like RB mentioned the cover rails have been raised though for extra clearance.
Old Mar 16, 2003 | 04:24 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I had the same rockers too. I pulled the braces out of some old valve covers just to see if it would clear, and it did.
The GM copmosite valve covers work perfect, but they are a bit pricey. They also keep down the valve train noise so any knock retard should be elimatied.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
