stupid air pump
Old Mar 13, 2003 | 04:26 PM
Z28Clone's Avatar
stupid air pump
replacing the 305 with a 350 in a 91 RS. keeping AC, so i transferred over the mounting brackets, etc.
to keep the same setup, belt, etc, i still have the air pump attached (but hoses and attachments are disconnected).
i went to turn the pulley that the air pump was attached to and it wouldnt budge. put wd40 in it to get it to move a little.
i read post on "time to srip" and someone said that the water pump will drain more hp then this pump.
should it turn more freely? well with the way its acting, it will drain alot of hp.
Old Mar 14, 2003 | 11:13 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
it should spin freely
Old Mar 14, 2003 | 12:26 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yeah they are supposed to spin freely, maybe it seized up?
Old Mar 14, 2003 | 01:43 PM
Vader's Avatar
stupid air pump
Of course it's stupid. It doesn't even have a processor.
Normally, and A.I.R. pump takes almost no power to turn. Yours' however, will take a lot, since it sounds like it's locked up. You can try to free it up, open and repair it, or get a junkyard (excuse me - "recycled") pump to replace it. You could get a new one, but th ecost can be prohibitively high. A remanufactured pump with a warranty is available at some parts stores, as long as you have a core to exchange (which, you DO). Advance Auto/Parts America has remans for $51.49 (plus the $15 core which you get back),which isn't oo bad if you have to pass an emissions inspection.
Old Mar 14, 2003 | 01:51 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Send me an email if you need a used pump. How's $15?
Cleotiz
Jan 6, 2018 08:56 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
