Fuel leak at vent line near charcoal canister??!!
Old Mar 14, 2003 | 07:39 PM
Nasty_Bird_'90's Avatar
I just got the new motor in my car and running. I had it on the lift tonight putting on the exhaust. After the car ran for about 10 minutes or so, I noticed a fuel leak from the front of the car. I thought one of my lines was loose. NOPE! It was coming from the solid pipe that runs to the charcoal canister. I don't have the canister in the car b/c I removed all of the emissions stuff so it just poured out. Obviously I have something plumbed wrong. Can one of you guys point me in the right direction? Please?!? Thanx.
Old Mar 14, 2003 | 09:40 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
man.......... you having that problem too? i have ALL the emissions and everything is STOCK(including routing). i have liquid fuel coming from there too. i feel your pain. i don't know what the *** is wrong.
man this car is being a serious bitch
Old Mar 15, 2003 | 10:10 AM
Vader's Avatar
Your optionsareto either replace the EVAP canister or cap the vent line from the tank. As the tank heats up, air in it will expand, causing any fuel vapor to purge out (what the EVAP is supposed to capture and control).
Old Mar 15, 2003 | 03:47 PM
turns out that I had two of the lines at the tank crossed up. The purge line and the return line were backwards. as soon as the engine heated up the purge valve opended releasing the gas that should have gone to the return line. I flipped them back and no more problems.
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
wayshegoes
Aug 17, 2015 12:00 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Kaweh
Aug 9, 2015 02:54 PM
