what starter to use with slp headers and kick out pan?
Old Mar 16, 2003 | 01:00 PM
P170412's Avatar
Hi,
I have SLP 3/4" headers and a Canton Kick out RR oil pan.
I can not find a starter which will fit. Can anyone out there
with this combo recommend a starter motor.
I have tried the CVR protourqe, which must have the motor
clocked down which contacts the Y-pipe.
I have tried the powermaster 9000, which can't have the solinoid
clocked down because it hits the oil pan and when clocked up it
is so tight between header and block i can not fit a heat shield
and get heat soak.
Please help, I'm tired of buying starters.
Old Mar 16, 2003 | 01:21 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If an adjustable ministarter like this CSI won't work, then you
simply have to switch to a different pan.
Old Mar 16, 2003 | 02:06 PM
Morley's Avatar
Go back to the powermaster and try a remote solinoid.
Old Mar 16, 2003 | 08:32 PM
P170412's Avatar
Morley,
I asked the powermaster tech line about a remote
solenoid. They seemed to think it wouldnt help. Something
about the attatched solenoid still be involved. I didnt fully
understand the explanation.
Have you successfully used a remote to solve this type of problem? If so I'll give it a try.
Old Mar 16, 2003 | 08:41 PM
Morley's Avatar
No, I've never run into a clearance problem like that one. I don't see why it wouldn't work though, it should eliminate the need for a starter mounted solinoid, unless I'm missing something.
Old Mar 16, 2003 | 10:48 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The starter simply cannot engage the flexplate without a solenoid.
You're thinking of a remote relay to cause the solenoid to engage.
No it won't help.
With the adjustable starters you can move the solenoid to different positions.
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
downsouthboy
Aug 29, 2015 11:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
